Brake fluid advice - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Technical > Brakes
Old 06-09-2017, 20:46   #1
6evo
Brake fluid advice
I upgraded the brakes on my vi about 2 years ago to pagid rs15 pads all round, hel lines and motul rbf600 fluid, I am about to do another track day and wanted to know if I should replace all the fluid or just bleed some through? Also should I start with the calliper furthest from the master cylinder to nearest? Also on the fronts is it the inner or outer nipple first?
6evo is offline   Reply With Quote
Old 06-09-2017, 21:39   #2
robert12345
robert12345's Avatar
I would bleed a fair amount though to make sure you have got any moisture out of the brake system. And yes start from the furthest brake caliper first then work your way back to the closest one to the master cylinder . And do the out side nipple first on the brake calipers .i always bleed a good amount of brake fluid before every event on my rally car with new motul rbf600
robert12345 is offline   Reply With Quote
The Following User Says Thank You to robert12345 For This Useful Post:
6evo (07-09-2017)
