Rear shocker removal on driveway - Mitsubishi Lancer Register Forum
Old 01-04-2020, 16:54   #1
Humps85
Wanting to fit some lowering springs to the Bilsteins on my ix, planning on doing it on the drive. The fronts and rears both look an easy job but having watched the rear shockers being replaced by a mechanic a while ago with the car on a ramp it looked a bit awkward to get the strut back in the bottom arm as he really had to swing on a pry bar to get the arm low enough to get the strut bolt through.
Will this be a pain on a jack and axle stands or doable with a big bar and a bit of elbow grease ??
Humps85 is online now   Reply With Quote
Old 01-04-2020, 16:56   #2
leeslancer8
leeslancer8's Avatar
Car: EVO 8 260 - EVO 7 RSII - EVO 8 FQ320 MR - EVO 4 GSR
Nah it’s do able shouldn’t be too much hard work
leeslancer8 is offline   Reply With Quote
The Following 2 Users Say Thank You to leeslancer8 For This Useful Post:
gaz007 (01-04-2020), Humps85 (01-04-2020)
Old 01-04-2020, 17:02   #3
Humps85
Yeah what I thought, summat to do in the current climate !
Old 01-04-2020, 18:11   #4
McGoo60
You shouldn’t have to swing on the lower arm at all, undo the bottom arm at the hub and the strut, fit the strut at the top, fasten the lower arm at the hub, use a jack to lift the hub to insert the bolt in the strut bottom.
The Following 2 Users Say Thank You to McGoo60 For This Useful Post:
Old 01-04-2020, 22:05   #5
gaz007
Car: evo 6 tme ,gems ecu ,mapped by steve simpson,,380bhp 359lb ft t apexi ebc,
It's a 20 min job each side
shaken but not much
gaz007 is offline   Reply With Quote
Old 02-04-2020, 07:05   #6
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
But once you've changed the springs, strictly speaking, you should get the alignment redone.
Phil
Old 02-04-2020, 07:07   #7
Humps85
Yeah will be doing once this lock down is over.....whenever that maybe ! Won’t be driving it until then.
The Following User Says Thank You to Humps85 For This Useful Post:
plip1953 (02-04-2020)
