Flashing out EGR and Immobiliser - Mitsubishi Lancer Register Forum
Old 04-03-2020, 19:25   #1
Mita
Evening all..
I have a IX ECU that still has the immobiliser on it, I also need to have the EGR flashed off too as itís going in to a 5 so donít want a warming light. Is this something that can be done on the bench? Along with a base map ?
Old 04-03-2020, 21:05   #2
MHR Evolution
Car: Evo 6.5 TME Edition
Originally Posted by Mita View Post
Evening all..
Think you can turn those functions off with ecuflash
Sent from my D6503 using Tapatalk
MHR Evolution is offline   Reply With Quote
Old 05-03-2020, 05:21   #3
Mita
Yes pretty sure thatís the case
My issue is can this be done on the bench?
Old 12-03-2020, 17:50   #4
Mita
Anyone?
Old 12-03-2020, 19:01   #5
donner
User
Yes you can bench flash no issues. If you use jdm IX rom (which I would prefer anyway), theres no need to disable EGR as it does not have it.
donner is offline   Reply With Quote
The Following User Says Thank You to donner For This Useful Post:
Mita (12-03-2020)
Old 12-03-2020, 19:05   #6
Mita
Well thatís good info thanks mate
So I guess to bench flash one would need a harness ?
Would a tuner/mapper be able to do this? Or can I do it? I just need a base map to get to the tuner!
Old 13-03-2020, 09:09   #7
Ads9
Ads9's Avatar
Car: EVO IX FQ320, 2.2 Cosworth, TT S214b, Link G4+ Geekmapped by me (hasn’t gone bang. Yet.)
Grants may be worth a PM.
In theory you'll need to just hook up the 3 power connections and OBD comms wires. Bit of a pain in the bum for a 1 off job IMO.
Any reason you can't plug it into someone else's car to power it up and flash the data bits you need?
Ads9 is offline   Reply With Quote
The Following User Says Thank You to Ads9 For This Useful Post:
Mita (13-03-2020)
Old 13-03-2020, 13:33   #8
Mita
Thanks again
As you can now see , I will put the ECU in the car and then use a cable and EvoScan . Itís for a MIVEC 5rs so I just wanted to make sure I can start up and have a base map for any issues, an MOT and then Mapping
Old 13-03-2020, 13:35   #9
Mita
I’ve looked at Evoscan , admittedly not a lot as I’m away at the min. Is it pretty straightforward? It looked a bit hard to navigate. I guess it’s ok to use on a MacBook Pro ?
Old 14-03-2020, 11:06   #10
Ads9
Ads9's Avatar
Iíve looked at Evoscan , admittedly not a lot as Iím away at the min. Is it pretty straightforward? It looked a bit hard to navigate. I guess itís ok to use on a MacBook Pro ?
Have you had a read of Merlins Guide (it is on the Evoscan website) as that will answer your question ref the immobiliser.
I haven't run it directly in OSX, I have parallels desktop and Win 7 and Win 10 as VMs which work fine for all ECUs I've played with.
Mita (14-03-2020)
Old 14-03-2020, 13:15   #11
Mita
Thatís a good shout I will have a look at it
