ECU flash problem - Mitsubishi Lancer Register Forum
Old 01-02-2020, 07:50   #1
jambo360
User
ECU flash problem
I am trying to read the rom file of a evo 6 with ecu flash but keeps coming up with a error! Anybody else had this problem!?
jambo360 is offline   Reply With Quote
Old 01-02-2020, 10:21   #2
nplatenkamp
If you use a Tactrix 2.0 Openport cable, it might be the ecu is locked.
Or cable connector issue ?
Else you can try using an other/older Ecuflash version.
nplatenkamp is offline   Reply With Quote
Old 01-02-2020, 15:12   #3
jambo360
User
Thanks for that! If it is locked can it unlocked cheers
Old 01-02-2020, 20:11   #4
nplatenkamp
If it is locked by Ecutek, I believe only them can unlock it.
You can try ecu unlocker. Do a search in google.
Old 09-02-2020, 07:17   #5
jambo360
User
Thanks tried ecu unlock matrix one and no didn't work! What I don't get is if it has been hit with ecutec software why is it still stock power! Are there other things that can stop it reading!? Is it worth trying with the 1.3u lead instead of op2!?
Old 09-02-2020, 12:55   #6
nplatenkamp
No, 1.3 won't work on a 6. You can try other Ecuflash version.
Did you check if it is an ecu of a 6 ?
Old 13-02-2020, 06:55   #7
jambo360
User
Ok I try that! Do you 1.42 or 1.38
Old 22-02-2020, 01:28   #8
Evolover9999
User
Car: Evo lX
Lee5 is an ECU Neurologist I believe he’s ur man
Evolover9999 is offline   Reply With Quote
Old 04-03-2020, 21:08   #9
MHR Evolution
Car: Evo 6.5 TME Edition
You have the jack/map wire plugged in to the tactrix cable?
Sent from my D6503 using Tapatalk
MHR Evolution is offline   Reply With Quote
