Mitsubishi OEM Turbo Codes - Page 2 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 29-04-2011, 10:38   #16
youngsyr
youngsyr's Avatar
Car: Evo VIII FQ 330 Sold, now in a BMW M3 (V8)
That's what it says on the UK Mitsubishi site that I linked - all of the FQ models come with the TD05HA turbos.
youngsyr is offline   Reply With Quote
Old 09-05-2011, 11:38   #17
youngsyr
youngsyr's Avatar
Just seen a 260 turbo (single flapper 9.8T) with the code 01540, will update the table when I get a chance.
Old 02-09-2011, 15:12   #18
MidnightE6
MidnightE6's Avatar
Car: Sensible Years
Wow, reading this has lost me completely now.
As it seems the MR and Evo6 Turbo have the same code?
So would an MR turbo NOT be an upgrade for the VI then?
MidnightE6 is offline   Reply With Quote
Old 02-09-2011, 15:26   #19
youngsyr
youngsyr's Avatar
The "code" simply describes the core/compressor/turbine size, direction of flow and materials - but there's more to a turbo than that.
In the case of the VI vs VIII MR turbo, there isn't much difference between them. The only difference that I'm aware of is the single flap wastegate arrangement on the VIII MR turbo compared to the dual flap wastegate arrangement on the VI turbo.
Old 19-09-2011, 11:02   #20
Tommyturbo
Tommyturbo's Avatar
Car: Evo 6 GSR
Would I be right in thinking my brother VI RSX has the same turbo as a RS then.
The turbo has a horrible whine and he one of those guys that like to have the correct turbos as the car is totally standard...
Tommyturbo is offline   Reply With Quote
Old 19-09-2011, 11:35   #21
youngsyr
youngsyr's Avatar
I'm not sure which model the VI RSX is based on, but bearing in mind that the RS models in Japan could be ordered with either the RS turbo or the GSR turbo as a factory option, it doesn't really matter which turbo is fitted for authenticity's sake.
However, if fitting a different type of turbo, even if only the turbine wheel material is different, a remap would be needed.
The best way to find out which turbo is fitted to your brother's car is to attach a small mirror to a stick and check the code on the compressor housing against the table on page 1 of this thread.
Old 03-01-2013, 21:09   #22
adrianojp
New Evo 8 Turbo Code
Hi To all,
I have taken a picture of my cold side turbo casing today, and I can't find it in the box on the first page. The last two letters are different...
My turbo code is: 49378-01540
Anyone know what turbo this is? I have searched the internet and found it is a 9,8 hotside 16G, this model: TDO5HR-16G6/9.8T
This turbo should be Inconel...
[IMG][/IMG]
[B]• Project "Pirate" Evo - build thread here[/I]
adrianojp is offline   Reply With Quote
Old 08-01-2013, 13:48   #23
youngsyr
youngsyr's Avatar
More than likely a VIII 260 turbo - with the single flap wastegate on a 9.8T hotside.
The table on the front page mainly lists all the JDM/FQ turbo codes. The VIII 260 is UKDM, so is not on there.
Old 08-01-2013, 16:48   #24
adrianojp
Ok, thank you!
Old 05-02-2013, 19:39   #25
bobs day
my e4 turbo code
49178-01510 is this standard?
bobs day is offline   Reply With Quote
Old 05-02-2013, 21:36   #26
youngsyr
youngsyr's Avatar
Looks like it is:
Evolution 4
p/n = 49178-01510
Turbo = TD05HR-16G6-9T
Nozzle Area (cm2) = 9
TD05HR turbine = Inconel (steel alloy)
Compressor 16G6 = Aluminium
Inducer = 48.3mm
Exducer = 68mm
Turbine housing = twin flapper
>>LINK 1<<
>>LINK 2<<
Old 08-02-2013, 17:46   #27
bobs day
tnx
Old 11-02-2013, 08:19   #28
adrianojp
I found the following information on a Tomei Arms description page, hope it helps:
ALL MODELS OF THE STOCK MITSUBISHI LANCER TURBINES
STOCK MODELS EXPLAINED
(Example) TD05HRA-155G6mC-10.5T
TD05HHH This shows the tubine housing type used. The larger the number the larger the housing.
R After the EVO 4 the turbines were reversed.
A Shows that a Titanium turbine wheel is used.
155G Shows the size of the compressor housing used.
m Shows that a Magnesium compressor wheel being used.
10.5 Shows the size of the exhaust housing used
T Shows the twin scroll design as used on EVO 4 onwards models.
MODEL GLADE TURBINE MODEL CW TW
1 GSR RS TD05H-16G-7 AL INC
2 GSR RS TD05H-16G-7 AL INC
3 GSR RS TD05H-16G6-7 AL INC
4 GSR RS TD05HR-16G6-9T AL INC
5 GSR RS TD05HR-16G6-10.5T AL INC
6 GSR TD05HR-16G6-10.5T AL INC
RS TD05HRA-16G6-10.5T AL INC
6TME GSR TD05HRA-15GK2-10.5T AL INC
RS TD05HRA-16G6-10.5T AL TI-AL
7 GSR TD05HR-16G6-9.8T AL INC
RS TD05HRA-16G6-9.8T AL TI-AL
8 GSR TD05HR-16G6-9.8T AL INC
RS TD05HRA-16G6-9.9T AL TI-AL
8MR GSR TD05HR-16G6-10.5T AL INC
9 GSR TD05HR-16G6C-10.5T AL INC
GT/RS TD05HRA-16G6mC-10.5T MG TI-AL
9MR GSR TD05HRA-155G6C-10.5T AL TI-AL
RS TD05HRA-155G6mC-10.5T MG TI-AL
10 GSR TD05HA-152G6-12T AL TI-AL
RS TD05H-152G6-12T AL INC
CODES EXPLAINED
CW Material of the Compressor Wheel
TW Material of the Turbine Wheel
AL Aluminum Alloy
MG Magnesium Alloy
INC Inconel
TI-ALM Titanium Aluminum Alloy
Old 22-05-2013, 16:04   #29
Glebe1981
Glebe1981's Avatar
hey i have a turbo not listed and wondered what it was off.
49178 01520
td06hr-16g6-10.5t
been told its an 8 mr turbo but want to check.
Glebe1981 is offline   Reply With Quote
Old 29-01-2014, 19:40   #30
Jonty234
GTA Turbo code
For reference the code from my GTA turbo is:-
49378-01500
HR-15GK2-9.0T
Jonty234 is offline   Reply With Quote
Similar Threads
AMS GT35R Turbo Kit Mitsubishi Lancer EVO Evolution 4>9 [email protected] Silver Option Traders 2 10-10-2010 22:22
Stunning Newly Forged Mitsubishi Evo 8 FQ330 Genuine example £9495 Paza3 Private Sales - Cars 6 29-07-2010 10:45
Dropped my Car off at Indigo JMT Lancer Chat 69 07-12-2008 18:17
found this about my car duran Non-Lancer Chat 7 01-09-2005 13:04
FORZA MOTORSPORT XBOX nick5 Non-Lancer Chat 89 26-05-2005 21:39
