Ecuflash and evoscan - Mitsubishi Lancer Register Forum
Old 21-07-2019, 11:14   #1
evo_ac
I'm having issues with evoscan and ecuflash.
I've not used it for a while (about 4 years on my old evo 6 and j now have a 5.
Evoscan issue
Get the following when logging
Info Battery less than 0.304v
Error less than 5v Deteceted at cable
Ecuflash
I keep getting j2534 error when reading
So far I've tried
Ecu unlocked
Boosting from another car to get 13amp supply, without boost battery is reading 12.03
Wiped from computer and redownloading
Different usb leads
Tried my old computer with an old version of both programmes that I know did work still get the same
What's best to try next???
evo_ac is offline   Reply With Quote
Old 21-07-2019, 20:07   #2
Hic
Proper standalone ecu.
Hic is offline   Reply With Quote
Old 22-07-2019, 08:39   #3
pmugabi
Car: Evo 4 with E8 ECU, XS Engineering 272 cams, 80 series turbo
You probably have a broken lead at the OBD2 port.
Good thing the OBD2 port has only a few wires. Start by checking the 12V power to the OBD2 port and then go from there.
pmugabi is offline   Reply With Quote
Old 22-07-2019, 13:21   #4
evo_ac
Evo ecu casing with the main chip number h8/539.
Voltage at obd 4.70 v should this be 12v?
Old 23-07-2019, 09:22   #5
evo_ac
I took 12v supply to the obd port still the same errors
