4 to 3 plug conversion harness - Mitsubishi Lancer Register Forum
Old 25-11-2009, 14:55   #1
Grant620
Gizzmo Distributor
Grant620's Avatar
Car: 640hp GTX3576R EVO VI Race Car
Hi there
Would there be much call for a 4 to 3 plug conversion harness?
IE a patch loom with a 3 plug male connector to plug into a late 8/9 ECU and a female 4 plug connector to plug into a 4/5/6/7 loom?
Grant620 is offline   Reply With Quote
Old 25-11-2009, 15:03   #2
[email protected]
antony@Indigo-gt's Avatar
Car: Cayman GT4, MK7 Golf R and Tiguan R
Apexi do a cable to plug a 7 ecu into an 8 but not visa versa
antony@Indigo-gt is offline   Reply With Quote
Old 25-11-2009, 15:06   #3
youngsyr
youngsyr's Avatar
Car: Evo VIII FQ 330 Sold, now in a BMW M3 (V8)
I'd imagine the Evo IV owners would be happy to have access to them, but I'm not sure how many of them there are around any more?
Are all the Tephra mod options currently available on the 5 and 6 ECUs - might make it more attractive if they can easily swap in an VIII ECU with the mods on?
youngsyr is offline   Reply With Quote
Old 25-11-2009, 15:07   #4
[email protected]
Evo 4 is same plugs as later cars
Old 25-11-2009, 15:11   #5
youngsyr
youngsyr's Avatar
But my point was that it cannot be ECUFlashed, AIUI, so swapping in a later ECU might be a better option.
I guess you could swap in another 4 plug ECU, but as above, I'm not sure whether you can get the full Tephra mods on ECUs earlier than the VIII, hence the need for the loom to swap to a 3 plug ECU.
Old 25-11-2009, 15:12   #6
Grant620
Gizzmo Distributor
Grant620's Avatar
The S-D mod is not available on 5/6 ECU, so you need a 7/8 260 one.
The 3 plug ECUs seem less popular (due to wiring) so I thought making some loom patches would make the ECU market more open?
Might be prohibitively expensive... Around £150 per loom.
Old 25-11-2009, 15:16   #7
evonut270
Car: evo 2 with an 8 ecu
thats the problem grant.thats what apexi charge for a harness.id build the looms if i had access to the plugs.
evonut270 is offline   Reply With Quote
Old 25-11-2009, 15:20   #8
Grant620
Gizzmo Distributor
Grant620's Avatar
Apexi harness goes the other way though doesn't it?
Old 25-11-2009, 15:24   #9
youngsyr
youngsyr's Avatar
It's a nice idea, but at that price I think people would just try to find a VII or VIII 260 ECU.
I imagine you'd also need to have different looms for several different combinations to cater for all the different ECUs and cars they can go in? E.g.:
VIII MR -> IV
IX -> VI
VIII -> V
It would be nice to get everyone to settle on one ECU for future development (e.g. IX ECU) and then just create the looms to get that ECU working on all the cars. That way the maximum development time can be spent on the ECU itself, but I guess even then there will be glitches when it's patched into the different models.
Old 25-11-2009, 15:28   #10
Grant620
Gizzmo Distributor
Grant620's Avatar
I've got a 9 ECU here you see and want to fit to my 4, but it looks like it's a fair bit of work?
With 7 / 8 260 ECUs being around £175 it seems to make financial sense to make a patch loom for the 9 ECU!
Just thought I'd offer the option to other people as well (and hopefully bring the cost down)
Old 25-11-2009, 17:04   #11
DesEvo 8
adaptor loom
Hi Grant,db gauge arrived today,I think adaptor loom would be a good seller i've purchased a 9 ecu as i plan to go the SD route and would need a loom to adapt my 4plug 260 to 3 plug 9ecu,cheers DES
Des gsr
DesEvo 8 is offline   Reply With Quote
Old 25-11-2009, 17:09   #12
evonut270
yeah 3-4 plug on the 1 2 and 3s.problem being as soon as a loom becomes available the prices on the ecus goes up.if i can get plugs from an evo 8 3 plug harness i may convert to a 9 ecu from the 260 item i have currently.
Old 25-11-2009, 19:10   #13
grayw
Car: Evo
Nice idea Grant, but maybe prohibited by price. I know Grants looked into getting the 3 plug connectors for the VIII & IX ECU but they were silly expensive due to the amount required for a purchase.
You can run the 96260009 or 90550001 SD patch on the 4 plug 260 ECU, just for info. The IX ECU and rom presents some issues when installed into a VIII.
grayw is offline   Reply With Quote
Old 25-11-2009, 21:43   #14
Grant620
Gizzmo Distributor
Grant620's Avatar
So at the moment, a 7 or 8 260 ECU is the best way forward for S-D?
Old 25-11-2009, 21:43   #15
Grant620
Gizzmo Distributor
Grant620's Avatar
What would be silly expensive for the plugs?
