Best oil choice for forged Evo 6 - Mitsubishi Lancer Register Forum
Old 09-06-2019, 09:35   #1
EVO_STEW
Car: EVO 6 RSX
Hi, I have a fully forged Evo 6 and currently run it on Millers nanodrive 5w40 fully synthetic. Just wondered if they was a better weight oil to use or still to what I use. Cheers
Evo 6 RSX
EVO_STEW is offline   Reply With Quote
Old 09-06-2019, 09:45   #2
mlau1294
mlau1294's Avatar
If youíre still at standard / Stage 1 power then 5W40 should be fine but if youíre at higher power then you could likely benefit from a different weight oil like you said.
My 9 is running 470 and I use 10W50.
Old 09-06-2019, 09:45   #3
McGoo60
I use Millers nanodrive 10w60, my engine builder recommended it.
Old 09-06-2019, 15:59   #4
EVO_STEW
Car: EVO 6 RSX
Cheers for the replies. It’s currently running 375 Bhp but have all the bits to go to 480 Bhp + so I might look at changing the oil on the next change. Thanks again.
Evo 6 RSX
Old 14-06-2019, 20:54   #5
Clivew
Transmission Dynamics
Clivew's Avatar
Originally Posted by EVO_STEW View Post
Cheers for the replies. Itís currently running 375 Bhp but have all the bits to go to 480 Bhp + so I might look at changing the oil on the next change. Thanks again.
The oil weight should be matched to suit the engine bearing clearances and normal operating temps that is specific to your usage and spec.
[email protected]
The Following 2 Users Say Thank You to Clivew For This Useful Post:
Mita (14-06-2019), Sparksgsr (19-06-2019)
Old 15-06-2019, 07:13   #6
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Out of interest, which out of "bearing clearances and normal operating temps" is the more important? I'm assuming, perhaps totally incorrectly, that a 10W50 will be "thicker" than, say, a 5W30 (through a temp range of 70-100 degs C), and therefore better suited to an engine with larger bearing clearances?
Or is it a whole lot more complex than that?
Phil
Old 19-06-2019, 18:48   #7
col_2
i was recommended the same 10w60 nano plus hks oil filter
col_2 is offline   Reply With Quote
