CV axles same or different from 5/6 to 7/8/9 - Mitsubishi Lancer Register Forum
Old 09-02-2008, 21:39   #1
RtsEVOIV
Car: 98 E5 GSR
Are the front CV axles different for the 5/6 vs the 7/8/9? I assume they are, but if not that would be great.
Also, can I swap 7/8/9 front hubs on the car and use 7/8/9 axles? thanks
Ryan
RtsEVOIV is offline   Reply With Quote
Old 09-02-2008, 21:42   #2
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
Ryan
Front outer CV and shaft are different, hubs are different too
Stu
Old 09-02-2008, 21:56   #3
RtsEVOIV
Car: 98 E5 GSR
So is it possible to swap the hubs from a 7/8/9 to a 5/6? would you jhust have to use the outer cv joint on the 5/6 shaft? thanks
Old 10-02-2008, 06:49   #4
stu8
stu8's Avatar
Nope the later shafts are a bigger diameter, you may get away with swopping full shafts, hubs and struts, i dont know. Why would you wnt to do this?
Stu
Old 11-02-2008, 18:49   #5
RtsEVOIV
Car: 98 E5 GSR
the new hubs are stiffer as theyre forged, and theyre readily available in the US where as evo 5/6 ones arent. I know about the struts being different at the hub, but thats not a big deal. anyone else have this info? if the front hub/strut/axle will swap from a 7/8/9 into a 5/6?
Old 11-02-2008, 21:32   #6
spn
spn's Avatar
Car: EVO 6
There's going to be another issue with the bottom balljoint, it's different on the later models. I'm not sure how it compares to the one on a 5 - you may be able to do something.
Cheers,
Simon
spn is offline   Reply With Quote
Old 12-02-2008, 00:27   #7
RtsEVOIV
Car: 98 E5 GSR
So, can I go with the front control arms, hubs, struts and axles? I can easily find all that for cheap over here.
Old 12-02-2008, 21:38   #8
YZR
Car: Evo 6 T/M Edition.Evo7 RS, Evo 9 RS
You need evo6tme rs2 (gsr front arm the same?) front lower arm, balljoint of the evo7/8/9 reduced of 0.5mm in diameter with lathe machine and press into the arm.
The steering end rods is mounted upsidedown on the evo7/8/9 hub, a good machining workshop can solve the "cone" trouble.
Evo 7 rs 10.841 216.87kmh
First Evo in Italy in the [email protected]
YZR is offline   Reply With Quote
Old 12-02-2008, 23:30   #9
RtsEVOIV
Car: 98 E5 GSR
Shouldnt all the 5/6 front control arms be the same?
Old 18-02-2008, 13:53   #10
udt98
they are not interchangable and the best way to resolve the problem. put the Evo 8 subframe on Mirage. then steering rack, transfer case and front suspension problems will be resolved.
udt98 is offline   Reply With Quote
Old 18-02-2008, 23:54   #11
RtsEVOIV
Car: 98 E5 GSR
Uh, mirage? I have an actual evo 5... whats a mirage have to do with it? Can you elaborate? thanks
Ryan
Old 19-02-2008, 17:05   #12
udt98
well... Mirage and EVO 4/5/6 share the chassis. The front half is very same and evo 7/8/9 use toatally different subframe and control arms. and different diameter axles knuckles and hubs. BTW, why do you want to upgrade to EVO 8 suspension system? I'm currently looking for EVO 5 if you are thinking about to sell the car, I'm the potential buyer lol
Old 19-02-2008, 19:57   #13
RtsEVOIV
Car: 98 E5 GSR
They arent even close to the same chassis. they just have the same mounting points. evo chassis are usually 100-150% stiffer than the base chassis, or more.
No, im not wanting to sell. the new hubs are stiffer, have better geometry, and are available locally. good luck on your search for a 5, theres only ~5 in the country.
Old 03-05-2020, 18:56   #14
EvoVI_PR
Reviving this old thread.
Hey, RtsEVOIV, were you ever able to switch your car to modern Evo8 hubs in the front?
I need to replace my front hubs in an Evo6 and they are not readily available in Puerto Rico, like the Evo8 ones are.
Thanks,
JCG
EvoVI_PR is offline   Reply With Quote
Old 03-05-2020, 20:12   #15
McGoo60
They haven’t logged in for 9 years so unlikely you will get a response.
