Max boost for Ralliart 260 ECU? - Mitsubishi Lancer Register Forum
Old 05-09-2010, 10:24   #1
pkn
What is the max acceptable boost for a Ralliart 260 ECU? I have an HKS EVC-S boost controller fitted and it's running 1.6 bar on the high setting. Is this too high or can boost be increased up to 1.7?
pkn is offline   Reply With Quote
Old 05-09-2010, 10:37   #2
starkers
Regional Organiser
starkers's Avatar
Car: 2L Forged, GT30, Self Mapped Apexi D-jet
Send a message via MSN to starkers
Unfortunately it's not just as easy as upping the boost and off you go unless your not bothered about your engine pal
You'll need to get knock and AFR's checked to ensure everything is running ok as each car reacts different dependant on other mods
However the RA maps are done for 1.5bar iirc
Engine built, mapped and maintained by me
Insured with PaceWard
starkers is offline   Reply With Quote
Old 05-09-2010, 17:28   #3
pkn
Thanks mate, will keep it on low boost then which is set to 1.5. That will do until I get the standard ECU in and ECUTek'd
Similar Threads
Fitting a Ralliart ECU to EVO6 CLaNZeR ECU / Mapping 13 01-07-2008 20:39
Todays G-Force Results Mosi Lancer Chat 119 28-06-2004 21:39
Autronics ECU boost control Spanpody Technical Questions 10 28-03-2004 00:00
Rescheduled G-Force Dyno Day 28th Feb Mosi Rolling Road Days 120 29-02-2004 09:46
Boost Controllers and New ECU DaveG Engine / Turbo 1 08-01-2002 21:01
