fuel pressure and boost settings greddy proflec b please - Mitsubishi Lancer Register Forum
Old 04-01-2010, 11:43   #1
seahaven shaun
shaun
seahaven shaun's Avatar
Car: 5!! SIERRA RS COSWORTHS,ANGLIA RACE CAR,MK2 GOLF DRIVER,EVO 7 PROJECT STARTING SOON!
Hi guys,like to just check some settings before i start going for a blast.
i have a sard fuel pressure reg
and greddy proflec b spec 2 boost controller.
i have defi gauges for boost and fuel pressure.
what should the fuel pressure be static or at idle and again at full boost?
i have a ralliart ecu and want to run 1.5 bar boost in my evo 6.
what should i have the gain and start boost set to for 1.5 bar please?
thanks shaun
IM IN EVO WORLD AGAIN
seahaven shaun is offline   Reply With Quote
Old 04-01-2010, 12:19   #2
grayw
Car: Evo
I would set the fuel pressure to standard (around 3 bar with the vacuum pipe disconnected). As for the boost controller, start at a low duty and work upwards.
grayw is offline   Reply With Quote
Old 04-01-2010, 14:05   #3
seahaven shaun
shaun
3 bar at idle?
Old 04-01-2010, 14:07   #4
grayw
Car: Evo
Yes at idle with the vacuum pipe disconnected.
Old 04-01-2010, 15:10   #5
seahaven shaun
shaun
thanks gray,been reading up on setting boost controller,do i set the start boost close to the boost i want to reach?
