Evo 8 ABS light on!! - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Technical > Brakes
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 20-07-2012, 16:06   #1
Evo8Frankie
Car: Evo VIII 260 #214 - 400/400 - Black Beauty
Arrow Evo 8 ABS light on!!
Hi people, i currently have a E8 and the ABS light is on, how do i go around sorting it without spending any money ,
thanks
Evo8Frankie is offline   Reply With Quote
Old 20-07-2012, 16:11   #2
HPWJman
Have you pulled the codes?
HPWJman is offline   Reply With Quote
Old 20-07-2012, 16:16   #3
Evo8Frankie
Erm no, tbh mate unsure on you mean, lol my mates coming round tommorrow with his fault finder to have a look, is there a main sensor on the car like under the driver side front wheel arch?
Old 20-07-2012, 17:08   #4
HPWJman
Ok, all you need to do is bridge pins 1 & 4 on the OBD port with a paper clip and count the number of flashes - Long flashes are 10's and short flashes are 1's.
The OBD port is located under the dash, drivers side footwell.
Easy enough to do mate, 5 min job
Need anymore help, just ask
Old 20-07-2012, 17:53   #5
Evo8Frankie
right got cha mate, ill have a look tommorrow when my mate get to mine, hes a mechanic you see lol, but yeah thanks very much and yeah will do mate cheers
Old 20-07-2012, 18:42   #6
Evo8Frankie
right iv just checked and there two, a black one under my left knee as im sat in the seat in a silver metal housing, and there a smaller white one, attatched to the side of the silver metal housing, i take its the black one as the white one has prongs coming off it?
Old 21-07-2012, 10:07   #7
Evo8Frankie
bump
Old 21-07-2012, 10:58   #8
Capt.Mike
Car: BMW M4
yes. obd is the black one
Capt.Mike is offline   Reply With Quote
Old 21-07-2012, 11:39   #9
Evo8Frankie
yeah ok thanks, so if i bridge the ports 1&4 will it reset the light or will it just tell me the fault code?
cheers
Old 21-07-2012, 13:33   #10
Evo8Frankie
right iv bridged pins 1&4 and seen it flashing long and short, will this eventually stop, or will it continue to flash, and also is the snow,gravel and tarmac lights suppose to flash with the abs light, im quite puzzled by this,
thanks
Old 21-07-2012, 13:56   #11
tones61
Car: vw polo R line,dax rush cosworth powered,ZX6R,
you have to count the flashes for the code number,
long flash is a 10,and short flash is a single number,add them together for the code number,
ie/4x long flash and 3x short flash will be code 43,
if its got wheels or boobs,,,sooner or later its gonna cost ya!!!
tones61 is offline   Reply With Quote
Old 21-07-2012, 13:59   #12
tones61
switch ign on but do not start and the engine light will flash out the codes on the dash clocks ,
long flashes = tens ,
short = units ,
so 2 long and 3 short = code 23
short steady flashes = no codes
to clear the the codes undo the Negative battery terminal for a few mins
and all code should be clear unless the fault is still there etc
have look here at the link not a Mitsubishi but you get the point of flashing
these are some codes that might help
96 -00 mitsi eng codes
11 Oxygen sensor fault.
12 Airflow sensor fault.
13 Intake air temp sensor fault.
14 Throttle position sensor (TPS) fault.
15 Idle speed control (ISC) motor position sensor fault.
21 Coolant temp sensor fault.
22 Crankshaft position sensor fault.
23 Camshaft position sensor fault.
24 Vehicle speed sensor fault.
25 Barometric (BARO) pressure sensor fault.
31 Knock sensor fault.
32 MAP sensor faulty.
36 Ignition timing adjustment signal fault.
39 Oxygen (O2) sensor fault.
41 Injector(s) fault
42 Fuel pump fault.
43 EGR fault.
44 Ignition coil (cylinders #1 & #4) fault.
52 Ignition coil (cylinders #2 & #5) fault.
53 Ignition coil (cylinders #3 & #6) fault.
55 Idle air control (IAC) valve position sensor fault.
ABS codes
11 Wheel speed sensor (FR) system (open- or short-circuit) 35B-8
12 Wheel speed sensor (FL) system (open- or short-circuit) 35B-8
13 Wheel speed sensor (RR) system (open- or short-circuit) 35B-8
14 Wheel speed sensor (RL) system (open- or short-circuit) 35B-8
15 Wheel speed sensor system (abnormal output signal) 35B-9
16 ABS-ECU power supply system (abnormal voltage drop or rise) 35B-11
21 Wheel speed sensor (FR) system 35B-8
22 Wheel speed sensor (FL) system 35B-8
23 Wheel speed sensor (RR) system 35B-8
24 Wheel speed sensor (RL) system 35B-8
32 Acceleration sensor (longitual acceleration) circuit system 35B-13
33 Stop lamp switch system (open circuit or stop lamp stays ON) 35B-15
41 Solenoid valve (FR) system 35B-15
42 Solenoid valve (FL) system 35B-15
43 Solenoid valve (RR) system 35B-15
44 Solenoid valve (RL) system 35B-15
51 Valve relay system 35B-17
53 Motor relay system 35B-19
63 ABS-ECU failure Replace ABS-ECU.
71 Acceleration sensor (lateral acceleration) system 35B-20
ayc etc
12 power supply open or short circuit
21 fr right wheel speed sensor open or short circuit
22 fr left wheel speed sensor open or short circuit
23 rear right wheel speed sensor open or short circuit
24 rear left wheel speed sensor open or short circuit
25 wrong diam tyre
26 faulty wheel speed sensor
31 steer sensor system(st1,st2,stn)open circuit
32 steer sensor stn short circuit
33 steer sensor stn system
34 steer system st1 st2 short circuit
41 tps open or short circuit
51 longitudinal acc sensor open or short circuit
52 longitudinal acc sensor
56 lateral acc sensor open or short circuit
61 stop lamp switch system open-circuit
65 abs monitor system open or short circuit
71 proportioning valve system open or short circuit
72 directional control valve right open or short circuit
73 directional control valve left open or short circuit
81 ayc relay system open or short circuit
82 electric pump system
83 electric pump system13 - Fail-safe relay system fault
81 - Pump relay open or short circuit
82 - Pump malfunction or sensor failure
Code 84 should reset itself upon switching off/on the ignition
The Following 2 Users Say Thank You to tones61 For This Useful Post:
Dave2011 (23-07-2012), qad (23-07-2012)
Old 21-07-2012, 14:47   #13
Evo8Frankie
right thanks very much for that in depth information, real help,,
so just to clarify the code will just keep repeating itself over and over??
ill get straight on it now thanks again pal
Old 21-07-2012, 17:13   #14
tones61
aye,it will repeat,
Old 21-07-2012, 17:21   #15
Evo8Frankie
yeah thats good mate nice one,
The Following User Says Thank You to Evo8Frankie For This Useful Post:
55 chevy (06-07-2015)
