EVO 8 anti roll bar diameter - Mitsubishi Lancer Register Forum
Old 06-09-2020, 16:09   #1
EVO8ARD
Hi from France, what anti roll bar diameter do you recommend me to run on my Evo 8 for only road tarmac use (no trackday) ?
I'm going to fit Ohlins R4 shock, 50 N/mm front ; 60 N/mm rear
EVO8ARD is offline   Reply With Quote
Old 11-09-2020, 16:21   #2
sfg
I see people use rear whiteline 24 mm and I use 25 mm Perrin with uprated mounts that come with the bar. Uprated roll bar end links that use spherical bearings such as whiteline etc [iirc] a good idea. I am limited by traffic and police where I live but after a 1 hour drive just now and trying to make the car misbehave occasionally, roll was not a problem [for me with my use].
I have oe springs/ bilsteins, oe front roll bar, 6 degrees caster, perrin 25 mm rear arb with whiteline end links at front, whiteline RCK at the front [which apparently also reduces roll at the front amongst other things], yoko a052 tyres.
sfg is offline   Reply With Quote
