Low engine oil light - Mitsubishi Lancer Register Forum
Old 11-10-2019, 08:57   #1
Naw
Hi guys , been trying to search this but had no luck , so hope you guys got any ideas to help me out . My car is an Evo X 2011 MR SST , been driving around for over 3000 km after engine build ( sleeved block , rods and pistons , cams and valves and a Garrett G2 GTX3576R , oil restrictor included . Car drives and shifts perfectly, no oil burnt , smoke and level after 3000 km like at start . After driving it at a sustained high speed of about 5 mins at 150 mph , my engine oil level light comes on , so I slowed down turned into a petrol station and checked oil level and it was perfect, tried a few other high speed pulled but not for very long time , did not happen again , car has a driven fab catch can too , any ideas on what could cause this , the sensor is perfectly connected, thx in advance.
Naw is offline   Reply With Quote
Old 11-10-2019, 09:14   #2
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Definitely oil level? I would try overfilling by half a litre. Are you seeing any/much oil in the catch tank?
Phil
Old 11-10-2019, 12:20   #3
LEGNUMVR4
Is your oil grade suitable for sustained 150mph blasts?
5mins is a long time at that speed.
LEGNUMVR4 is offline   Reply With Quote
Old 11-10-2019, 12:50   #4
Naw
Low oil level light
No , just those smelly vapors but hardly anything apart from the oil look inside catch can , the oil I am using will check exact name but itís 5W -50 Fuchs Titan , I had the oil level past the full mark at least 1/2 liter , could be slightly less or more , was filled to nearly that blurred mark above the hole for full level .
Old 11-10-2019, 13:20   #5
grants
grants's Avatar
Just a thought. Does the X MR have a combined sensor for both level and temperature?
The EUDM Evo 8 had such a sensor, possibly also fitted to USDM cars?
Old 11-10-2019, 13:52   #6
kikiturbo
Car: EVO 9 GSR
yeah,
eudm cars have level sensor that liked to go bad..
I think evo X has the same
Old 11-10-2019, 14:13   #7
Phil2333
Tarmac Tyre Shredder
Phil2333's Avatar
Car: Evo 6, Forged 2ltr 8MR engine...405/400
5 mins at 150mph?...where were you?
My Evo 6 resto thread...
https://www.lancerregister.com/showth...ht=restoration
Phil2333 is offline   Reply With Quote
Old 11-10-2019, 14:39   #8
ypvs
ypvs's Avatar
Car: Silver 260 . On the up!!
My evo 8 has such a sensor until i re wired it to always off. It had a mind of its own, right pain in the back side!!
ypvs is offline   Reply With Quote
Old 11-10-2019, 15:14   #9
Naw
Low oil level light
This is a 60 km motor way which has hardly any cars and perfect long stretchís which you can see for miles , totally safe to get to those speeds and unless itís a bird or small animal that might get in your path , could go flat out for most of the way except for the petrol station area approximately in the middle , I could say itís just outside Madrid , but as we know it would be illegal to do this there , it was in Germany
Old 11-10-2019, 15:18   #10
Naw
Low oil level light
Yes I think my Evo X has that sensor which I checked and was connected solid , but donít think itís that as after I pulled over and checked oil level was correct , I did few more pulls even dropping down to 5 th gear at 7500 rpm and light did not show again , the only thing this were just like 1 min to 30 sec pulls .
Old 11-10-2019, 15:21   #11
Naw
Low level oil light
I will have that sensor tested just to be sure .
