Twincharged complete - Mitsubishi Lancer Register Forum
Old 08-06-2018, 16:40   #1
jbakerevo
Decided to start a new thread now the car is complete. The spec is as follows
ND 7R turbo kit
ND long rod drop in forged job
Wire rung head gasket and wire ring process on head
ND Intercooler and pipes
ND Supercharger kit
S90 throttle body
New K&N air filter for SC kit
ID1340 injectors
Walbro 400L in tank pump fitted and hardwired
Exedy twin plate HD clutch and bearing
Link G4+ Ecu
ND V3+ dry sump kit
ND Splittable special tank
ND Oil tank bracket
25 Row HD dash 10 oil cooler
Breather tank
Braided Hose line kit
94mm billet crank
2.24L pistons 4G63 set
ARP main stud kit
Set engine bearings
Block machining
Link Can Lambda & Uprated Knock Sensor
ND S3 Ported Head Etc +1mm and +2mm, Ti’s, Springs, guides etc
TOMEI 270 11.5mm CAMS
Work emotion wheels
Kuhmo V70A tyres
Meister R Gt1 suspension
safety device roll cage
6 pot AP Racing front brake kit
corbeau Carbon race seat
Driveshaftshop Carbon fibre prop
Quaiffe centre diff
Driveshaft shop front and rear 900hp shafts
Definitely would've missed a few bits out but thats the majority of the spec.
jbakerevo is offline   Reply With Quote
The Following 10 Users Say Thank You to jbakerevo For This Useful Post:
D2 (09-06-2018), dreMR (09-06-2018), evo stew (09-06-2018), JasonL91 (09-06-2018), KJC (08-06-2018), milosavljevicm (08-06-2018), octainejunkee (09-06-2018), Realbadman (08-06-2018), Sir Marcus (08-06-2018), strange_days_uk (08-06-2018)
Old 08-06-2018, 18:01   #2
Unobtainium
Unobtainium's Avatar
looks laggy
My latest thread: Kenny1's Evo 5 RS - Throughout the years
Unobtainium is offline   Reply With Quote
Old 08-06-2018, 19:49   #3
jbakerevo
are we looking at the same graph ?
The Following User Says Thank You to jbakerevo For This Useful Post:
Phil555 (08-06-2018)
Old 08-06-2018, 21:07   #4
Realbadman
Realbadman's Avatar
Car: Evo x FQ-360 (standard but nt 4 long)
Send a message via Yahoo to Realbadman
Have you’d driven her yet?
Realbadman is offline   Reply With Quote
Old 08-06-2018, 21:22   #5
river evo 6
river evo 6's Avatar
Originally Posted by Unobtainium View Post
looks laggy
looks amazing mate
Evo6 gsr, mapped by evotune.
Power = full
Torque = sometimes.
river evo 6 is offline   Reply With Quote
The Following User Says Thank You to river evo 6 For This Useful Post:
jbakerevo (08-06-2018)
Old 08-06-2018, 23:37   #6
jbakerevo
Not yet mate, first time will Be next weekend
Realbadman (09-06-2018)
Old 08-06-2018, 23:38   #7
jbakerevo
Originally Posted by river evo 6 View Post
looks amazing mate
Cheers mate, really pleased
Old 08-06-2018, 23:58   #8
milosavljevicm
milosavljevicm's Avatar
Car: EVO IX FQ340
milosavljevicm is offline   Reply With Quote
Old 09-06-2018, 00:19   #9
Bava
Bava's Avatar
what running gear do you have gearbox? diff front rear etc apart from quaife?
Link to my EVO 8 restoration and Evotune stroker build
https://www.lancerregister.com/showthread.php?t=504168
Bava is offline   Reply With Quote
Old 09-06-2018, 10:00   #10
jbakerevo
For now just the standard rs running gear
Bava (09-06-2018)
Old 09-06-2018, 10:39   #11
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
looks laggy
Isn't the "looks laggy" comment essentially regarding what the supercharger is (or isn't) actually doing?
Isn't the idea of the supercharger purely to help speed up turbo spool time? And yet the big numbers don't really start to happen until after 4500rpm! On the other hand, I guess you are actually going to feel the benefit of higher than usual torque (on a big power Evo) a bit lower down the rev range which should make it feel quite punchy for normal road use.
It will be interesting to see how it actually drives, so keep us posted
Phil
Old 09-06-2018, 10:43   #12
Mita
I must admit I expected a bigger surge earlier from the SC and then on to the larger turbo? It looks like it will drive like an NA car (a bloody quick one)
I would imagine a twin turbo set up would give more punch down low?
Old 09-06-2018, 10:58   #13
jbakerevo
At just over 2000 rpm the charger is making over 1 bar and 300 ft/Ib I think it’s going to climb the Rev range fast. I’ll have to get some footage when it’s on the road
The Following 2 Users Say Thank You to jbakerevo For This Useful Post:
Mita (09-06-2018), Realbadman (09-06-2018)
Old 09-06-2018, 11:09   #14
Mita
Great, it would be really interesting to see
Old 09-06-2018, 11:12   #15
H18BY0
... now with more Bang :)
H18BY0's Avatar
Car: Slagged Red Evo 6 tme (ex 6 silver tme owner) & 95 white Astra Merit (auto :)
That looks mad!
:::::::::::::::::::::: Tommi Mäkinen ////////// Edition No.13 ::::::::::::::::::::::
_______________________________________________________________________
::::::::::::::::::::::::::::::::::::::::::::: Signed, stickered and decatted : ) v
H18BY0 is offline   Reply With Quote
