E8 Coolant reservoir question - Mitsubishi Lancer Register Forum
Old 16-08-2016, 16:34   #1
bennyp
bennyp's Avatar
Car: EVO 8 MR 320 (415/405)
2 hoses going into top, where does the one closest to wing attach to or is a vacuum pipe??
Any help appreciated!
Ben
EVO VIII MR Built by DYNOTECH
bennyp is offline   Reply With Quote
Old 16-08-2016, 16:35   #2
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
Ben
not sure on later cars, but id guess 1 is just a vent?
Stu
CPP Motor Developments -
RG Motorsport -
Old 16-08-2016, 17:13   #3
sparkso
sparkso's Avatar
Car: Evo VIII MR FQ340
one closest to the wing is just a vent for the coolant tank and just seems to run down into the arch a bit and stop
sparkso is offline   Reply With Quote
The Following User Says Thank You to sparkso For This Useful Post:
wuldo (16-08-2016)
Old 16-08-2016, 22:51   #4
wuldo
Car: Evo 7
It's just an overflow for the reservoir
wuldo is offline   Reply With Quote
Old 17-08-2016, 12:07   #5
bennyp
bennyp's Avatar
Perfect, thanks chaps
Old 17-08-2016, 14:50   #6
Rampant
Profound thinker
Rampant's Avatar
It's more of an expansion tank and has a proper purpose.
The pipe going down into the tank that also connects to the top of the radiator should be submerged in coolant fluid so that it is able to "suck" fluid back into the system when the system cools down and the fluid inside contracts, but is free to vent fluid into the reservoir when hot (and consequently air being expelled from the expansion tank vented out to atmosphere).
I've seen some running dry or with fluid lower than the pipe from the radiator, which isn't a great idea.
Hope that helps
Cheerz
Mark H
Je cherche l'orgasme d'auto
J'ai trouve l'orgasme d'auto
The Following User Says Thank You to Rampant For This Useful Post:
bennyp (17-08-2016)
Old 17-08-2016, 15:54   #7
bennyp
bennyp's Avatar
Good, clear explanation. Thanks
