Cold start troubles - Page 2 - Mitsubishi Lancer Register Forum
Old 12-01-2019, 14:50   #16
Jim Salter
Replaced the IACV and the problem is still there.
Any other ideas?
Jim Salter is offline   Reply With Quote
Old 12-01-2019, 14:54   #17
Jim Salter
Am thinking of trying the starter motor next
Old 12-01-2019, 16:26   #18
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
Try the following: turn on ignition and wait 5 secs, you may hear fuel pump prime, turn off ignition and back on, wait a couple of seconds before cranking. The fuel pump will prime twice if you do this helping to build up fuel pressure and if that starts better then could be the fuel pump objecting to the cold.
TrickyDick is offline   Reply With Quote
The Following User Says Thank You to TrickyDick For This Useful Post:
Jim Salter (12-01-2019)
Old 12-01-2019, 17:46   #19
Jim Salter
Will give it a bash
Old 12-01-2019, 18:40   #20
Jim Salter
Having replaced the IACV I have now introduced an idle problem (D'oh!).
Old 13-01-2019, 13:16   #21
Jim Salter
Car is idling at 2000 rpm h
Old 13-01-2019, 14:41   #22
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
See here to reset idle
Old 13-01-2019, 15:04   #23
Jim Salter
Thanks for that.
Tried that last night but no good.
Parked the stepper today with Evoscan and back to normal
The Following User Says Thank You to Jim Salter For This Useful Post:
TrickyDick (13-01-2019)
Old 13-01-2019, 15:05   #24
Jim Salter
Will keep this thread updated with the start issues
Old 31-01-2019, 12:09   #25
Jim Salter
Ok, so put back the original IACV and reset the idle. Startup problem still there.
The startup problem is getting worse 3-4 turns and the car won't start.
Replaced the battery last night and this issue still there this morning.
Things I think it may be:
1) bad earth - will test this theory later
2) Bad plugs - not sure if they would cause this symptom
3) Bad coils and/or leads - again not sure if they would cause this issue but I do have a slight miss under acceleration also.
Has anyone any other 'theories'?
Thanks.
Old 03-02-2019, 11:50   #26
Jim Salter
The start issue is continuing to get worse.
Have tested if it is a bad earth but that's not the issue.
Haven't checked the plugs or coils yet.
Is there anything else this could be?
Old 04-02-2019, 10:37   #27
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
Would a leak also cause this type of problem? (I know I have a leak in the throttle body area)
Is this still an issue? Having played with startup settings on my ViPEC it is quite sensitive to mix when cold so that could be a problem. The IAVC idle control has quite limited range so it relies on the various other "static" settings to start easily.
Any other symptoms once started and warmed a little or otherwise perfect?
You might find new plugs make it slightly better when they are super clean but will probably be short lived once plugs bed in.
Is it getting worse just because its been colder recently?
Jim Salter (04-02-2019)
Old 04-02-2019, 22:54   #28
Jim Salter
Yeah it's still an issue. The startup is getting worse. Before it would start and struggle and then start, now it is taking 4 or 5 to start: start/struggle/start (almost)/struggle/start (almost) and so on
The other symptoms are that the engine seems to be laboring and appears to be running rich - have had a quick chat with a local specialist (waiting for him to get back to me on taking the car in). There is an intermittent hesitation and the car is down on power.
Will take out the plugs this week and check the MAF (I'm not driving the car at the moment as a result of the issues.
Old 05-02-2019, 09:50   #29
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
Sounds like a more general problem than just the cold. Could still be something simple so good luck at the garage, hope you get it sorted soon.
Jim Salter (05-02-2019)
Old 05-02-2019, 15:28   #30
abdul100
I had a similar problem due to faulty starter motor
abdul100 is offline   Reply With Quote
The Following User Says Thank You to abdul100 For This Useful Post:
