Cold start troubles - Mitsubishi Lancer Register Forum
Old 21-12-2018, 22:36   #1
Jim Salter
Cold start troubles
Hello all, having a few cold start issues at the moment.
When the car (Evo VII) is started from cold it starts (kinda) hesitates, makes a 'noise' (can't really describe it, will take some video tomorrow) almost cuts out and then starts. When warm the car starts perfectly.
With this very limited (and shÝte description) any ideas? (things in my head are - crank sensor, cam sensor.
Any help appreciated.
Jim Salter is offline   Reply With Quote
Old 22-12-2018, 00:01   #2
Jim Salter
Also, no DTC's showing up on Evoscan
Old 22-12-2018, 15:42   #3
Jim Salter
Starts at 57 seconds
Old 22-12-2018, 15:47   #4
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
has it had a remap ???
often cold starting is down to poor start up maps .
Old 22-12-2018, 17:14   #5
Jim Salter
I flashed the std map on it when it was converted to manual and deleted the CEL, it was throwing for EGR.
Old 22-12-2018, 18:11   #6
knaggers
Junior User
It's the stepper motor on the inlet manifold. Had the same problem, fine when warm,as it's not needed. Very expensive for what it is! Do not buy cheap chinese copy off ebay, you'll have same problem in less than a year.
knaggers is offline   Reply With Quote
The Following 2 Users Say Thank You to knaggers For This Useful Post:
dowser (30-12-2018), Jim Salter (22-12-2018)
Old 22-12-2018, 18:24   #7
Jim Salter
Will try the stepper first I guess
Old 22-12-2018, 23:02   #8
will2
Regional Organiser
will2's Avatar
IACV issues ? One like this :
https://www.ebay.ie/itm/MITSUBISHI-L...-/252075785308
Or best try mr Rob maybe ....IF this is the problem of course
The Following User Says Thank You to will2 For This Useful Post:
Old 22-12-2018, 23:56   #9
Jim Salter
Thanks Will.
New and OEM will be my path this time, however, the one you linked would be a cheap way to confirm/eliminate the iacv as the source of the problem
Old 23-12-2018, 10:56   #10
Jim Salter
Would a leak also cause this type of problem? (I know I have a leak in the throttle body area)
Old 23-12-2018, 21:15   #11
will2
Regional Organiser
will2's Avatar
I recently changed my leaking throttle body ,but hadnt any starting issues like you ....however that means absolutely nothing
Old 23-12-2018, 22:08   #12
Jim Salter
Well, this morning it was fairly cold and the car started 1st time without issue?!
Old 27-12-2018, 12:14   #13
Jim Salter
And it's back again...
Really annoying me now.
Have ordered the IACV as a test but not sure if it's gonna be the culprit.
Any chance it's the starter motor?
Old 27-12-2018, 12:47   #14
McGoo60
What about the temp sensor, that helps at cold start and they are cheap!
Old 01-01-2019, 20:20   #15
Jim Salter
N/a
