hesitation, misfire on boost - Mitsubishi Lancer Register Forum
Old 19-01-2012, 21:19   #1
mac94
Car: Evo6 TME, Bmw M3 E30, subaru impreza, Golf Gti one
I have hesitation and slight misfire on boost with my evo 5 rs
with 1 bar boost the car run perfect
but with 1.2 bar i have hesitation and misfire on boost
I have
new actuator
new walbro
new plug gap 0.6
new coilpack
I try a different Maf and fuel regulator
what I have to check ?
the afr is perfect with 1,2 bar boost... with hesitation and misfire
no knock
thanks
mac94 is offline   Reply With Quote
Old 19-01-2012, 21:25   #2
Raph
Car: evo iv
mine runs fine on 1.3 bar boost,just running a mines ecu
maybe its just fuel cut due to the boost rising too quickly
if you acelerate moderatley to 1.2 bar..does it still hesitate?
And you are using 99/100 Oktan?
Press cntrl+alt+del to view sig.
Raph is offline   Reply With Quote
Old 19-01-2012, 21:35   #3
mac94
no it's not fuel cut
it's small hesitation
no it hesitate on full boost... moderatly it's okay
I use 98 ron
Old 19-01-2012, 21:36   #4
todd-w
todd-w's Avatar
Car: Evo5 Mivec Turbo
try regap the plugs to .65 mm
todd-w is offline   Reply With Quote
Old 19-01-2012, 21:38   #5
Raph
Car: evo iv
mine are 0.7
ive been seeing lots of flks with plugs gapped to 0.55 and 0.6 .. not necessary for a car running 1.2 bar on a standard turbo etc
Old 19-01-2012, 21:42   #6
Raph
Car: evo iv
I use 98 ron
Dann kann es nur eine kleinigkeit sein.
ist der kleine vacuum schlauch,der von EBV ans Ansaugschluch geht noch da?Sitz direkt hintern MAF und fällt raus bzw wird entfernt und das ganze EBV kurzgeschlossen beim MBC einbau.. meine war auch so, hab das Loch zu gemacht.Schaue doch nach
Und Kerzen bei o.65 oder 0.7mm und du verwendest NGKBPR8ES oder 7ES? kein Irridium käse?
Hast auch die Kerzensteckern geprüft,ob sie verbrannt sind?
Old 19-01-2012, 21:56   #7
Raph
Car: evo iv
Im not sure how close Schwietzer Duetsch is to german,hope you can read my message lol.
You could email me-ill email u my number and we could talk thru the problem.
What part of Switzerland are you in? Treid evo-forum.de, maybe a member there is willing to swap out eus to see if that changes it? doubt its an ecu problem tho.
Im about 5 hours from the swiss border,so kinda far just to swap bits.
Old 19-01-2012, 22:33   #8
todd-w
todd-w's Avatar
Originally Posted by Raph View Post
mine are 0.7
Its worth trying if it cures his issue
Old 20-01-2012, 06:16   #9
mac94
It's better for me that you write in english.... or french
because I understand a bit the german but not so good
I am from wallis.... french part
I have two evo and lot of friends of me have evo so it's not a problem for
me to swap parts....
what did you write about the oem solenoid ?
my oem solenoid is still in place with the wiring connected... but without hose comming in...
Old 20-01-2012, 06:26   #10
evo baz
MLR Oldie
evo baz's Avatar
What plugs are you using?
evo baz is offline   Reply With Quote
Old 20-01-2012, 06:27   #11
mac94
BPR8ES gap 0.6
Old 20-01-2012, 07:16   #12
stevov
stevov's Avatar
Car: EVO 5
You didn't mention plug leads in your list. Also try another set of plugs
stevov is offline   Reply With Quote
Old 20-01-2012, 07:26   #13
nplatenkamp
might be fuel filter and try with full tank.
nplatenkamp is offline   Reply With Quote
Old 20-01-2012, 07:34   #14
mac94
leads are new .. put in the car in the same time coilpack
fuel filter is new too
walbro is new with filter new
Old 20-01-2012, 07:50   #15
nplatenkamp
try with full tank, with my 6 when tank is 25% it starts cutting out, I guess fuel is swapping in the tank.
Rico
