1500rpm Idle - Mitsubishi Lancer Register Forum
Old 25-10-2019, 18:50   #1
ThatGreyEvo8
User
1500rpm Idle
Hi guys, just had Kelford 272 cams fitting and G4. All done by a professional garage and I have no problem with their work what so ever
BUT... Car is idling at 1500- Is this normal with cams fitted or does something need looking at? Iím going to speak with garage in morning but just wondered if anyone can shed light in mean time.
ThatGreyEvo8 is offline   Reply With Quote
Old 25-10-2019, 20:42   #2
nplatenkamp
Hi, if they also mapped it, they should look into it.
nplatenkamp is offline   Reply With Quote
The Following User Says Thank You to nplatenkamp For This Useful Post:
ThatGreyEvo8 (26-10-2019)
Old 25-10-2019, 21:41   #3
ThatGreyEvo8
User
Yea itís had Link ecu fitted at same time and full map. So youíre saying itís not normal with cams then?
Cheers mate
Old 25-10-2019, 22:00   #4
ragz
1500 is way to high
Mine sits at 950 to 1100
Whoever mapped it should sort that
ragz is offline   Reply With Quote
The Following User Says Thank You to ragz For This Useful Post:
Old 26-10-2019, 10:49   #5
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
Although you'll need a bit higher idle than stock with those cams the Link has excellent idle control and they should easily get it smoothly idling at 980-1000. It may need a tweak to the manual idle screw to centre the ICV stepper motor. It is fiddly to get the idle control right over the entire engine warm up though.
TrickyDick is offline   Reply With Quote
