[Evo X] When pressing brake pedal engine revs to 2000 rpm - Mitsubishi Lancer Register Forum
Old 23-10-2019, 11:44   #1
nplatenkamp
Question [Evo X] When pressing brake pedal engine revs to 2000 rpm
Hi,
my last issue is now the above. Engine revs to 2000+ when using brake, throttle position goes to 20 % exact for 1-2 seconds then rpm goes to idle.
Also the throttle is very responsive, 1 mm and engine jumps to 2200 rpm.
I flashed an oem rom 52680022.
Tested Map sensor, air leaks and brake booster all are good.
TPS also is working ok.
Anyone an idea ? I suspect a wiring issue....
Thanks,
Rico
nplatenkamp is offline   Reply With Quote
Old 27-10-2019, 14:32   #2
nplatenkamp
Hi, nobody a clue ? I checked all vacuum lines and also disconnected brake booster but
still same issue.
If I press the brake slowly, idle is ok, when releasing and brake light goes off the engine (throttle -> 20%) revs again to 2000-2200 rpm. Then goes back to idle.
Old 28-10-2019, 08:45   #3
Evo6er
Evo6er's Avatar
Car: EVO 8 MR
Have you reset base idle?
Instagram @palmaredevo
Evo6er is offline   Reply With Quote
Old 28-10-2019, 09:16   #4
nplatenkamp
Hi, no after cold start the idle is ok. As set in the map.
Old 28-10-2019, 13:13   #5
nplatenkamp
Hi, I found when unplugging brake light switch (at pedal), the brake issue is gone....
Maybe related to not using AYC ecu ?
Old 28-10-2019, 20:38   #6
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Brake issue? Don't you mean the rpm increase?
What do you mean by "not using ayc ecu"? Have you disengaged it's functionality? These cars are very complex electronically and even the most basic of actions can trigger unexpected consequences.
Phil
Realbadman (29-10-2019)
Old 28-10-2019, 21:06   #7
nplatenkamp
Yes, I mean idle stays the same. I do not use AYC so did not plug in the ayc ecu.
I will test again tomorrow and if needed I will change ETACS and see.
Old 29-10-2019, 08:48   #8
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
My MX5 has what to me is a slightly off putting and irritating feature that results in revs rising as you try to trickle away in first gear even though the throttle pedal hasn't been touched! In this instance I'm advised that it's some kind of pre-programmed anti-stall feature, and I'm pretty sure it's handled totally within the ecu (ie with the trigger being that an initial rpm drop is detected). But I also have a Merc with fly by wire brakes and for one of the features associated with this system to work (called SBC) it specifically needs to know several bits of info from various other seemingly unrelated sub-systems on the car. This can (and did in this SBC failure instance) make a troubleshooting quite tricky.
In your case you have clearly identified a link to the brake pedal switch, but sounds like there must be other conditions that are at play too?
Had the AYC system been disconnected for some time prior to first experiencing the rpm rise phenomenon?
Phil
