ECU Flash Advice - Mitsubishi Lancer Register Forum
Old 23-10-2019, 09:05   #1
Marty K.
ECU Flash Advice
I have managed to get an evo7 ecu working, sort of, with my evo 3 engine.
It runs it okay, but the problem I am having is with lambda.
I am simply not getting any readings whatsoever.
Its got a 2 wire lambda fitted in the standard o2 housing.
I have tried another o2 sensor, same result.
I do have a 4 wire lambda I could wire in?
The evo 7 ecu I obtained is running the Tephra mods, and I am uncertain exactly what has been done to the periphery settings and maps.
The ecu rom currently loaded is 96530006
Does anyone have a totally standard rom, I can use as a base to work from please?
I am wondering if some of the periphery settings are causing me some issues?
Many Thanks
Marty
Marty K. is offline   Reply With Quote
Old 23-10-2019, 17:42   #2
nplatenkamp
You mean readings in EvoScan ? Best is to use a wideband to tune engine.
nplatenkamp is offline   Reply With Quote
Old 25-10-2019, 11:51   #3
Marty K.
Now sorted.
Marty
Old 26-11-2019, 07:42   #4
Evo(v)
Evo(v)'s Avatar
Car: Standard evo iv
Originally Posted by Marty K. View Post
Now sorted.
Marty
What did you end up doing in the end? I'm thinking about getting a 7 ecu as a quick cheap upgrade for now for my 4, di you use evo scan with it?
Evo(v) is offline   Reply With Quote
Old 13-03-2020, 13:24   #5
sekreini
Originally Posted by nplatenkamp View Post
You mean readings in EvoScan ? Best is to use a wideband to tune liteblue engine.
Love this. Its pretty awesome.
sekreini is offline   Reply With Quote
Old 07-04-2020, 18:28   #6
AlexEvo26
Car: Evo 6 RS2 LHD
96530706 is normally E8 Rom-id. works nice flashed in E7 ecu ?
AlexEvo26 is offline   Reply With Quote
