[Evo X] Can not flash, headlight relay is ticking madly - Mitsubishi Lancer Register Forum
Old 20-10-2019, 11:18   #1
nplatenkamp
Question [Evo X] Can not flash, headlight relay is ticking madly
Hi,
as I turn the ignition on the headlight (xenon) relay is going nuts and flash fails.
Removing the relay flashing works ok.
Also when engine is running the right headlight is flickering although it is turned off. (left does not work)
If I turn light on it is ok.
Any ideas ?
Thanks,
Rico
nplatenkamp is offline   Reply With Quote
Old 20-10-2019, 11:55   #2
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
Suppose an easy place to start is test the relay, and control supply too it
Stu
CPP Motor Developments -
RG Motorsport -
Old 20-10-2019, 12:28   #3
nplatenkamp
The relay is ok, if I turn key to first position (ignition still off) both headlights work ok.
If the engine is idling only the right headlight is flickering (lights turned off, relay ticking fast). Turn lights on only right one is working.
It may be related to immobilizer (I disabled this in ETACS).
Old 22-10-2019, 14:22   #4
nplatenkamp
I found the problem, due to using different wirings looms the DRL was faulty.
Set DRL off via ETACS and all good.
