Evo ix Intermittent Electric fault - Mitsubishi Lancer Register Forum
Old 08-08-2019, 01:10   #1
JimMcfly
Every few weeks my daily driven stock 2006 Evo ix fails to start, normally after 4 or 5 days of not being driven but can also fail immediately after driving.
The ignition turns on normally then when I turn the key to start position everything blacks out, including power to interior lights and door locks.
The car powers up and starts normally again after disconnecting the battery for 30 seconds.
Any suggestions appreciated
JimMcfly is offline   Reply With Quote
Old 08-08-2019, 01:56   #2
kikiturbo
Car: EVO 9 GSR
I would try cleaning the battery terminals and changing the battery first
ACD/AYC pump repair video
Old 08-08-2019, 06:31   #3
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
Aren't what you describe the classic symptoms of a failing battery cell or cells ie one minute you get full voltage and next minute it can drop to around 10 volts. Have you actually tried measuring the output voltage?
Phil
Old 08-08-2019, 09:40   #4
JimMcfly
thanks Phil, yes I have checked the voltage output from the alternator and battery and both are normal. I also cleaned the terminals and replaced the battery but neither solved the problem. It seems like the disconnecting an reconnecting the battery resets something, perhaps a faulty relay ?
Old 08-08-2019, 10:24   #5
plip1953
Phil
plip1953's Avatar
Car: Evo X RS
So you're saying the battery voltage is good even when the car won't start?
Phil
Old 08-08-2019, 11:49   #6
Jakeh
Car: 9 Wagon
Might be worth checking it is not the infamous water in the passenger side wiring block issue.
https://www.lancerregister.com/showthread.php?t=355126
(also follow link to Steveolution's thread)
Jakeh is offline   Reply With Quote
Old 08-08-2019, 11:58   #7
JimMcfly
yes even with the new battery installed or with jumper leads connected the dash instruments will not light up until I disconnect and reconnect the battery.
Old 08-08-2019, 16:11   #8
JimMcfly
good tip, thanks very much. I have read though the thread and just inspected the connections and thankfully they all look clean and dry.
The Following User Says Thank You to JimMcfly For This Useful Post:
Jakeh (08-08-2019)
Old 09-08-2019, 09:01   #9
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
Chassis connection at end of ground cable (-ve) to battery?
TrickyDick is offline   Reply With Quote
Old 09-08-2019, 14:45   #10
JimMcfly
thanks, I have just checked ground cable and it looks secure and untouched since the factory.
Old 09-08-2019, 17:07   #11
swinks
swinks's Avatar
Car: ex-Mitsubishi Galant VR4, Mitsubishi Lancer Evolution 8 FQ300
Send a message via Skype™ to swinks
From my experience sounds like failing either ignition switch or wire connecting switch to starter. Very common in Mitsubishi Galant from mid 90s to mid 00s. Check switch for burned out pins or gunk residue. If OK, check if you have voltage at starter end after turning key into start position.
Very annoying and common problem haunting old Colts, Mirage and Galant
ex-Galant VR4: 269 WHP and 325 LbFt torque at 0.9 bar (stock engine, turbo and ecu)
Evo 8 FQ300: 325 WHP and 375 LbFt torque at 1.6 bar
swinks is offline   Reply With Quote
Old 10-08-2019, 16:48   #12
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
I had the starter motor push on spade connector fail a while back. However wire is more likely to fall out than be intermittant but worth a check.
If disconnecting battery always fixes issue then more likely that is resetting immobiliser etc. Does locking/unlocking doors also fix it?
Old 10-08-2019, 20:06   #13
JimMcfly
yes the starter connections look secure.
it is not just power to the starter that drops. it everything including the doors locks. It will unlock when I come out to the car then will all loose power when i get in and turn the key. could be an immobiliser fault.
Old 10-08-2019, 20:10   #14
JimMcfly
thanks I will pull out the ignition switch and inspect it tomorrow. The starter relay doesn't even click it, it is as if the batter isn't even connected even though the terminals are clean and secure.
Old 10-08-2019, 23:13   #15
TrickyDick
Very Senior User
TrickyDick's Avatar
Car: VII FQ-300x2
When you turn the key to crank it disconnects the power to the "key on" circuits and that is normal. You need to check the battery voltage to see if that drops, if so then it could just be a battery fault. Try switching on the headlights, if they dim significantly when trying to start then again it suggests a battery issue.
