EVO X - Program new Key to ECU ? - Page 2 - Mitsubishi Lancer Register Forum
Old 07-10-2019, 21:39   #16
Sephiro
Car: Evo X SST 330
Glad to hear you finally got it working.
Sephiro is offline   Reply With Quote
Old 13-10-2019, 09:56   #17
nplatenkamp
Thanks, but it runs not ok. So I downloaded OEM Rom (56910007_2011_EDM_5MT.hex) but this also shows greyed out tables in ECUFlash?
Can I write this or could it brick my ECU ?
The current rom is set for 1000 cc injectors.
Thanks, Rico
nplatenkamp is offline   Reply With Quote
Old 14-10-2019, 20:27   #18
Sephiro
Car: Evo X SST 330
I was under the impression that you could back up your existing ROM with ECUflash so in the worst case scenario you can write that back. I don't claim to be an expert on flashing the ECU, however as I've got a UK car with a locked ECUtek ROM so I can't use ECUflash.
Old 15-10-2019, 09:00   #19
nplatenkamp
Thanks, yeah I assume so but with so many entries greyed out I am not sure if a flash works 100%.
Old 15-10-2019, 12:57   #20
Sephiro
Car: Evo X SST 330
The ROM is just a binary dump of the everything in the firmware memory so if you write a stock rom (hex/bin file) without attempting to change it you should be okay.
The greyed out entries I think you are referring to are due to you having the wrong or out-of-date XML definition file as the XML file is used to map the content of the bin file to what it actually controls thus allowing you to make changes. Without the correct/complete XML file ECUflash won't know which address in the ROM file each setting relates to - think of it as a contents page for the ROM. Similarly if you attempt to modify the ROM using the incorrect XML definition then you will likely get an undesired (potentially engine killing) result.
Essentially the XML file needs to match the Rom Id of the rom you want to edit. Do you know the Rom ID of the stock rom you are trying to load?
Old 15-10-2019, 15:21   #21
nplatenkamp
Thanks, acc. to Ecuflash :
Internal ID: 52680122 Inherits: 52680022
Memory Model: M32186F8
I will do a test write first.
Old 15-10-2019, 20:58   #22
Sephiro
Car: Evo X SST 330
52680122 corresponds to the TephraV1 USDM 5MT rom for which you can download the correct XML file from:
https://www.tephra.it/v1/TephraXMOD-V1-52680122.zip
Which inherits from 52680022 which you can get from:
https://rallinspired.com/download/52...t-evolution-x/
Which inherits from 52680015:
So grab all those 3 XML files and stick them in the folder that ECUflash uses which I think might be the following and the relevant editing options should become enabled:
c:\program files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo\
Old 16-10-2019, 09:10   #23
nplatenkamp
Thanks, I have all these xml files, so I guess these entries were not yet defined.
Thanks again for your help. Today I will try to flash.
Old 17-10-2019, 08:07   #24
nplatenkamp
According to Ecuflash all went ok. So all sorted now.
Old 17-10-2019, 12:26   #25
Sephiro
Car: Evo X SST 330
Good to hear - I hope the car is running better afterwards.
I assume it was the 56910007_2011_EDM_5MT rom you applied this time as opposed to a vanilla version of the TephraXmod V1 rom you had on before?
Old 17-10-2019, 14:05   #26
nplatenkamp
Yes, on idle it runs great (after injector set to oem size)..
No, I modified the current rom, will check ofcourse if all is well.
Can I use a newer rom version (5691****) as I have 5268**** rom ? I read on a forum that you should use 5268**** roms.
Old 17-10-2019, 16:18   #27
Sephiro
Car: Evo X SST 330
I don't know for sure what the differences are, however I would assume that if the car is stock you want to use the map for the correct model/year of car as the differences potentially relate to aspects of the car that affect the map (like exhausts).
The 5268 is for the year 2008 car and 5691 is 2011. If your car is modded then I guess you'll need to tweak whichever map you use anyway, however I'd imagine it would still generally be easier to start with the base map for your model.
Old 06-01-2020, 21:25   #28
adomanim1
Originally Posted by nplatenkamp View Post
Hi,
I bought 2 new keys (used) and an ecu from an FQ360 (acc. to seller).
Can I disable the immobilizer with ECUFlash ? Or if the ecu is locked how can I remove the lock ?
And is there any tool besides MUT 3 to program keys to ecu?
I am unsure if the dealer near me can Tutuapp 9apps Showbox do this and it will be expensive to get the car there.
Can PM if you want.
Thanks,
Rico
if you know your old code, and know the new code in each module, you can switch the code between the two..
You need one working key for each immobilizer, if you have a working key, then you can yourself add additional keys.
To initially marry the immobilizer module to a key, and to the ECU, you still need the MUT..
adomanim1 is offline   Reply With Quote
Old 07-01-2020, 11:34   #29
nplatenkamp
Thanks, for me the best way was to disable the immo.
