4 to 3 plug conversion harness - Page 3 - Mitsubishi Lancer Register Forum
Old 28-11-2009, 16:45   #31
evonut270
Car: evo 2 with an 8 ecu
5 injectors are fine.
pin swap
pin 20-32
pin 21-34
if the car fails to start after the immob has been disabled swap round pins 8+22
iv probably forgotten something thats just off the top of my head.
evonut270 is offline   Reply With Quote
Old 28-11-2009, 16:51   #32
grayw
Car: Evo
Disable the immobiliser in the rom.
grayw is offline   Reply With Quote
Old 28-11-2009, 17:20   #33
cossie1
cossie1's Avatar
Car: Evoless :(
Switch off the 02 heater circuit check too, otherwise you will get a cel.
cossie1 is offline   Reply With Quote
Old 28-11-2009, 19:08   #34
todd-w
todd-w's Avatar
Car: Evo5 Mivec Turbo
Originally Posted by youngsyr View Post
I'm not sure whether you can get the full Tephra mods on ECUs earlier than the VIII,
EVO 7 ra rom 90550001 was the first rom to have tephra mods
todd-w is offline   Reply With Quote
Old 28-11-2009, 19:10   #35
todd-w
todd-w's Avatar
you need to run a wire to pin 79 for flash plug
Old 28-11-2009, 19:19   #36
Grant620
Gizzmo Distributor
Grant620's Avatar
Car: 640hp GTX3576R EVO VI Race Car
This has been done on my ECU (V Ecu in IV car) as it's had an RA map flashed in by GrayW
Cheers, Grant
01278287346 / 07718384822
Grant620 is offline   Reply With Quote
Old 28-11-2009, 19:36   #37
todd-w
todd-w's Avatar
then its just the other wire swaps
Old 28-11-2009, 20:47   #38
Grant620
Gizzmo Distributor
Grant620's Avatar
pin swap
pin 20-32
pin 21-34
So
20-32
21-34
8- 22
Also, noticed that the 8 ECU has a signal ground on pin 40 which is alarm warning on 5 ECU?
Lambda heater (on IV loom) doesn't seem to be there, but is there on pin 60 on V and VIII 260.
Pin 87 on V ECU is Idle switch, which is AYC/ACD on VIII 260... (no idle switch on 260 ECU, so disconnect this wire?)
So looks like a fair few wires to swap.
Cheers, Grant
Old 28-11-2009, 20:54   #39
evonut270
pin 40 isnt used on the 260 ecu.pin 60 (02 heater) is used on the 5 and 260 ecus.only change 8+22 if the car fails to start with the immobiliser disabled.i disconnected pin 87 when i converted my e2.
Old 28-11-2009, 20:55   #40
grayw
Car: Evo
For a 260 ECU into a IV:
Move 20-32
Move 21-34
Swap 8-22
Cut 87
Change periphery at FCA to 0x16D0 - Also remove the CAT overheat light.
Old 28-11-2009, 20:58   #41
Grant620
Gizzmo Distributor
Grant620's Avatar
Job done.
Cheers, Grant
Old 28-11-2009, 21:11   #42
evonut270
Originally Posted by Grant620 View Post
Job done.
have you got it running?
Old 02-01-2010, 01:59   #43
leong1
any body can help me . please
evo 3 to evo 7 ecu
have problem with swap ..
which one pin need to remove it ?
and with one need to swap it ?
any one have full detail pls pm me .
leong1 is offline   Reply With Quote
Old 08-03-2010, 15:50   #44
Grant620
Gizzmo Distributor
Grant620's Avatar
Just to clarify...
This is ECU Periphery 2?
And that 0x16D0 will remove immob and cat overheat?
Cheers, Grant
Old 08-03-2010, 15:53   #45
evonut270
Just to clarify...
what you looking to disable grant?
