Rear O2 CEL Warning - Ecuflash Fix Step by Step - Page 4 - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 51 votes, 5.00 average. Display Modes
Old 24-10-2008, 18:01   #46
grants
grants's Avatar
Gray
There are some, UK supplied ??, VII's with the rear lambda sensor
Pic from the "generic" VII WSM
Old 24-10-2008, 18:04   #47
adamarnold
adamarnold's Avatar
Car: Evo VII FQ300
Thats what mine looks like thanks Grants
adamarnold is offline   Reply With Quote
Old 24-10-2008, 18:09   #48
grayw
Car: Evo
Hi Grant, I have seen one fitted before, but it did not throw a CEL with a decat fitted.
grayw is offline   Reply With Quote
Old 24-10-2008, 18:12   #49
adamarnold
adamarnold's Avatar
Car: Evo VII FQ300
Ok thanks Graham I just wanted to be sure it would not cause any issues if I decat
Old 24-10-2008, 18:24   #50
grayw
Car: Evo
It was fine with a decat on the last one I played with.
Old 13-11-2008, 16:15   #51
Guille_evo
Car: Mitsubishi Lancer Evo VI RS-2
Send a message via MSN to Guille_evo
Hi, I┤m a new member but I read much in this forum. My English is not fluent. I want to see the possibility of mapping an ECU Evo VI. I have also EcuFlash, Evoscan and reprogramming cable. When I read the Rom with EcuFlash does not show anything in the left column. I apologize if this is cleared somewhere in the forum and I appreciate any information.
:m itsi:
:mit si:
:mitsi :
Guille_evo is offline   Reply With Quote
Old 13-11-2008, 16:19   #52
grayw
Car: Evo
You can read the VI ECU at present with Ecuflash, but flashing back is not possible at present with that software.
Old 13-11-2008, 16:35   #53
Guille_evo
You know the existence of any software capable of doing that?
:m itsi:
:mit si:
:mitsi :
Old 13-11-2008, 16:43   #54
grayw
Car: Evo
Ecutek can flash the V and VI ECU's.
Old 13-11-2008, 16:54   #55
hazzer
if the cel comes on will the car go in limp mode...
hazzer is offline   Reply With Quote
Old 13-11-2008, 20:20   #56
grayw
Car: Evo
No, but as I said in your other thread, If the CEL is on and another problem happens you will not know about it.
Old 01-04-2009, 09:34   #57
DanielN
Car: EVO9 GSR
Originally Posted by _Biggles_ View Post
How to fix your ECU to remove rear O2 sensor checks and CEL warnings after de-cat.
Hi Ladies and Gentlespoons. Many of us have had a decat. Some choose to fix the CEL indication by use of a special spacer or O2 simulator. Well i found O2 simulation too complex and fiddly to wire, the cel fix spacer from the states fouls the underbody on long journeys as the exhaust expands.
There has to be a better way.....
And yes there is! Been working with grayw today to eliminate the checks for the rear O2 sensor on a standard ECU. Today i can report thats now been fixed!!
So if _Biggles_ the ECU noob can do this, so can anybody.
OK you do have a list of bits to acquire so heres the list:
  • Laptop : DUH yep no laptop no ECU chatting, beg borrow, try not to steal
  • Limitless or Tactrix Cable : So those can be gotten from Grant @ Gizzmo Electronics (support your MLR trader!) or Limitless themselves
  • Ecuflash : Superb FREE software you are going to love forever after today acquired from www.openecu.org
  • Aktivematrix ECU Unlocker : Some ECU's are locked after tuning. BOO! This unlocks them. Go to www.aktivematrix.com, sign for free account, download it!
  • ROM Definition File : Different for every evo, but go to openecu.org and hit the forums they are all there! Look for your vehicle, if you are struggling to find it, make a post, someone will help you pick the right one!
  • You might also wish to consider Mitsulogger or Evoscan as well, you can check for knock etc with those! Evoscan is not free but its excellent. Useful for checking your engine & map health
So thats your parts and software list! Got it all? OK lets get on with fixing the CEL warning once and for all!
Hi mate,
Is this will work also for 88840017 Rom id?
DanielN is offline   Reply With Quote
Old 01-04-2009, 11:12   #58
grayw
Car: Evo
What car is 88840017 from? You would need to look at the periphery codes.
Old 09-04-2009, 12:54   #59
DanielN
Car: EVO9 GSR
Hi grayw,
88840017 is a EDM version rom id for Evo 9 2006.
This is my actual map now. 3 months ago I had 88840013 USDM version but I switch to 88840017 EDM.
I look into my periphery codes and I have in ECU periphery2 FCA bit4 enable P0300 value is 1.
This is the only thing that I did but after 100 km the cell is on again.
I do something wrong?
Old 09-04-2009, 14:59   #60
grayw
Car: Evo
This guide was written for the EDM VIII, so there may be differences. You could run a modified Tephra rom with the rear O2 simulator.
