A/C condenser - Mitsubishi Lancer Register Forum
Old 19-11-2017, 18:07   #1
swinks
swinks's Avatar
Car: ex-Mitsubishi Galant VR4, Mitsubishi Lancer Evolution 8 FQ300
Send a message via Skype™ to swinks
A/C condenser
I believe there are many ppl here who already did remove a/c system for track sake etc. Hence my question...
Myself, I got a/c condenser and coolant radiator holed while cruising on A14 near Cambridge by some metal object (bolt, nut?) flying from lorry in front of me.
How difficult is to remove a/c condenser itself and replace? I know I have to remove radiator first.
1. But, is condenser held by any bolts, or just slotted in position (pegs or pins)?
2. Will removing radiator give you enough space to access and remove a/c condenser? Or I need to remove front bumper as well?
3. Are two lines connecting to condenser secured by any sealing gasket, o-ring etc, or just self-sealing (undo nut/bolt, that's all)?
BTW, no gas in the system left, just green snots here and there, so no environmental hazard.
ex-Galant VR4: 269 WHP and 325 LbFt torque at 0.9 bar (stock engine, turbo and ecu)
Evo 8 FQ300: 325 WHP and 375 LbFt torque at 1.6 bar
swinks is offline   Reply With Quote
Old 19-11-2017, 19:19   #2
lemonnobby
Car: Evo ix fq300
Radiator is easy but the air con condenser isn't to bad once rad is out but i think there's bolts going though the front which means the bumper has to come off. But it might be easier just to see what your doing.
The pipes will have o rings on them.
Evo 9 FQ300
lemonnobby is offline   Reply With Quote
The Following User Says Thank You to lemonnobby For This Useful Post:
swinks (20-11-2017)
