what's the best spooling 500+ turbo??? - Page 2 - Mitsubishi Lancer Register Forum
Old 26-05-2011, 12:13   #16
evo baz
MLR Oldie
evo baz's Avatar
Originally Posted by Andy_8 View Post
Has a BBK Full made 500+ Dynodynamics on Vpower ? must of missed that ? the BBK-B seems to only just get over 500 on Vpower
Andy
Andy, my car made 390atw on dynodynamics. If you believe the 24% rule then that makes 513atf.
evo baz is offline   Reply With Quote
Old 26-05-2011, 12:15   #17
evo baz
MLR Oldie
evo baz's Avatar
Originally Posted by testa corse View Post
very good comparison, a dyno sheet of these two cars would help
On my phone just now but will try and find the links to the graphs later when i get home
Old 26-05-2011, 12:44   #18
Ian6
Ian6's Avatar
Car: 6 RS lightweight project
Originally Posted by antbern View Post
As for turbos. Any other options?
Hi Julian, in theory the GTX3076 would be the one to go for with your set up but i haven't seen any B2B results with other units.
Originally Posted by 4G63EvO View Post
Sweet, will try and be there if so will try and see you, hope it is Imtahleb.
Jon.
Jon, AFAIK Mtahleb will be on the 26th of June.
The Evolution, evolving and keeps getting better :-)
Ian6 is offline   Reply With Quote
Old 26-05-2011, 17:47   #19
spen123
Car: evo 8 MR
mine bbk-b did 402 ATW @1.9 bar b4 the head and manifold was done.
what boost you running BAZ...
spen123 is offline   Reply With Quote
Old 26-05-2011, 20:11   #20
evo baz
MLR Oldie
evo baz's Avatar
That was at 2 bar mate
My Graphs below. Don't think Fred posted his graphs but Nick did comment on how the graphs appeared to make it look as if the green HTA spooled up slightly slower but said that both cars drove exactly the same on the road. I think he also said that between the dyno runs some calibration or adjustment was made to the dyno so that may account for the slight difference.
Old 26-05-2011, 20:55   #21
Andy_8
Car: Evo VIII 260 "Standard".... tee hee
Cool I've got a 539bhp FP Green,
Ex-Evo VIII 500+
Andy_8 is offline   Reply With Quote
Old 26-05-2011, 21:07   #22
Conrad
#armchairtuner
Car: AE86 & EvoGTR project
Send a message via Skype™ to Conrad
24% nonsense
The graphs above 34 degrees on IT and no rpm pickup used
Conrad is offline   Reply With Quote
Old 26-05-2011, 21:42   #23
4g638
Buy a used fp red hta with wheels in good condition, it does not matter if it needs a core rebuild, convert it to bb core, run 1,8 bar and you are off to go
Marios
" Go tell the Spartans,passerby,that here by Spartan law we lie. " Leonidas I son of Anaxandritas II and king of Sparta,really proud to be his descendant!
4g638 is offline   Reply With Quote
Old 26-05-2011, 22:27   #24
spen123
Car: evo 8 MR
Originally Posted by Conrad View Post
24% nonsense
gear 3 used..
Old 26-05-2011, 22:40   #25
evo baz
MLR Oldie
evo baz's Avatar
The graphs above 34 degrees on IT :eek
Whats wrong with that?
Didn't you have something to do with TRL?
Old 27-05-2011, 07:09   #26
Dcevo
Car: Eurospec Time Attack Evo
should get some results on my s214 tt at the end of the week, spec changed a little, still 2.2, billet crank,Cosworth pistons, k1 rods, Cosworth Cams but nw with a jmf mani, HKS tubular elbow bit of custom work by alan and also a 3 inch HKS down pipe, plus loads more. So should be some good results
Follow on twitter @TeamEurospec
Follow us on Facebook
http://www.facebook.com/EurospecRaceTeam
Dcevo is offline   Reply With Quote
Old 27-05-2011, 16:04   #27
Ryan!!
Ryan!!'s Avatar
Car: Evo VI Track Car
ignore conrad baz!
General Rule is that as long as IT is within 10 degrees of AT it's fine.
Not sure on Vipec but if it's the same as Autronic the rpm pick-up doesn't work with them at Corten Miller.
Nick gets the rpm spot-on anyway.
Ryan!! is offline   Reply With Quote
Old 27-05-2011, 16:19   #28
evo baz
MLR Oldie
evo baz's Avatar
Originally Posted by Ryan!! View Post
ignore conrad baz!
Its cool Ryan, I'm not worried about him I was just going to quote Matt from TRL from THIS THREAD
Originally Posted by Matt TRL View Post
When im tuning on the dyno a good IC will normally Run air temps between 25-30 degree c at an ambient of 10-15 degree c
Matt
and then say that surely if Matt is happy with 15 degrees difference between ambient and inlet temps then my 10 degrees is fine
I have absolutely no doubt that if something was iffy at all with the map/temps/graphs that Nick wouldn't have let me take the car away until it was sorted
Old 27-05-2011, 16:22   #29
Ryan!!
Ryan!!'s Avatar
I think it's more the cooling of the dyno cell that has Conrad going but 10 degrees is fine.
Old 29-05-2011, 11:55   #30
antbern
antbern's Avatar
Car: Evo 6 hillclimb prep'd
What about manifolds?
antbern is offline   Reply With Quote
Similar Threads
Turbo leak Meer Engine / Turbo 21 16-02-2010 11:38
HKS Turbo Timer Type 1 weekenny Private Sales - Parts 4 30-06-2007 13:46
King of Europe - Fastest 1/4 mile car... Belgium6 Lancer Chat 55 28-06-2005 18:43
