Mystery clutch problem!! - Mitsubishi Lancer Register Forum
Old 11-06-2009, 11:33   #1
antbern
antbern's Avatar
Car: Evo 6 hillclimb prep'd
hi, im currently running an hks twin plate clutch. when its in gear, clutch down (disengaged) and i rev the car upto 5-8k the clutch automatically engages and jolts forward. my mechanic had a look at the clutch, everything looks normal, can anyone suggest the cause of the problem.
cheers
antbern is offline   Reply With Quote
Old 11-06-2009, 12:12   #2
Ian6
Ian6's Avatar
Car: 6 RS lightweight project
What is your clearance like?
When is your clutch engaging in relation to the pedal travel?
Are you using the original hydraulic clutch set up? (slave cylinder or a hydraulic release bearing)
The Evolution, evolving and keeps getting better :-)
Ian6 is offline   Reply With Quote
Old 11-06-2009, 12:18   #3
antbern
antbern's Avatar
as regards clearance we've tried varying it, and even at high clearance it still does it. The clutch engages when the pedal is still to the floor. not sure about the hydraulic clutch set up :-(
julian
Old 11-06-2009, 12:43   #4
Ian6
Ian6's Avatar
Jul,
Are you sure it is an HKS kit????
If the clutch is engaging when the pedal is still at the bottom you must have problem with your slave/ master clylinders, this is based on the fact that you said you have already tried to adjust the clearance but then again you wouldn't have and pedal feel.
Other than that it would be a knackered press plate.
Old 11-06-2009, 14:40   #5
antbern
antbern's Avatar
thanks alot, i'll check that out
Old 14-06-2009, 08:52   #6
Ian6
Ian6's Avatar
Jul,
Did you manage to find uot what the problem is/was?
