The ongoing money pit! - Page 2 - Mitsubishi Lancer Register Forum
Old 21-12-2016, 13:13   #16
RabRS
Car: 6 GSR > 6.5 TME > 9 FQ360 > 10 FQ360
The comedy on this thread is strong
Photobucket suck donkeys.
RabRS is offline   Reply With Quote
Old 01-05-2017, 12:00   #17
adamfitz
another little update from the winter fiddling!
Bought some bush for the rear end as some were looking a little tired.
Found some crack to go with the bush
so a new arm was replaced and fitted. All good. also cured a knock that seemed to have materialised last summer. so guessing thats when it decided it no longer wanted to function properly!
Decided to become Picasso for the afternoon and gave the Diff a lick of paint while it was out. Anyone that wants portraits/animals or similar done, hit me up!
Fitted a baffled sump that id had sitting in the box since Xmas. Deiced i didnt like fitting it just once I would do it 3 times because the dam thing leaked from the flanges
Had a little tidy up in the arches etc and my rather sorry looking filler neck and guard were tidied up and given a coating of the black stuff. Hopefully be good for eternity
Dropped the car off to have the scaffolding fitted mentioned earlier in the thread. only to find out our good friend iron oxide had decided to take up residency in my footwell. out with the grinder!
Once done, scaffolding was fitted and a rather tidy job done. Cheap plug for Hard knocks speed shop
Then decided i needed to go a bit more 'full race car' so though i would give SVA a run in the aero department.
Cue splitter fitting
Then after all this, was at Japfest yesterday and got the old girl out on the track for a shakedown. Nothing broke/fell off and no new funny noises materialised!
Future plans include trying not to break anything else! A slight whine has been about which i need to investigate further. But now time to enjoy it and get some track days under my belt
adamfitz is offline   Reply With Quote
The Following User Says Thank You to adamfitz For This Useful Post:
Mikeb1984 (01-05-2017)
Old 01-05-2017, 14:01   #18
Jabo
Track days are that I own the car for . Change your fluids often, make sure you do slow warm up laps and then cool down laps and she will purr for you like a kitten .
2010 stock Evo X FQ-330 daily driver
Jabo is offline   Reply With Quote
Old 01-05-2017, 15:09   #19
NJEvo9MR
NJEvo9MR's Avatar
Car: 2006 Evo IX-MR,6-Speed, 1989 'Starion Widebody both since new. 2012 Mitsu. Outlander Sport 'SE'/RVR
Best of luck! Too much fun here! Lol.
*2006 GGP Evo IX-MR, (owned since new) Cusco 7-point Roll Cage,Cusco full chassis brace kit & front power bar,GSC-S2 cams, Cusco front sway bar,Robi-Spec rear adjustable sway bar,FortuneAuto coilovers,ADVAN RS Rims,Voltex GT hood,CF headlights,ARC front splitter canards,WORKS short throw-shifter,WORKS full 4 point boot cage,HKS RS Intake,Mona Lisa ex. manifold, Buschur ported OEM throttle body&intake manifold, AMS intercooler,plus...
NJEvo9MR is offline   Reply With Quote
Old 01-05-2017, 16:16   #20
kikiturbo
Car: EVO 9 GSR
I had the same cracking tracking arm issue on two evo 9's... these cars do not like road salt..
Old 01-05-2017, 17:32   #21
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
ive seen cracked toe links on a few cars now 8s and 9s ,not easy to spot so i bet there hundreds of car out there with the same issue
Old 01-05-2017, 18:03   #22
kikiturbo
Car: EVO 9 GSR
true.. it is hidden by the splash shield.. IIRC..
I just welded up some new..
Old 01-05-2017, 18:41   #23
Kevin Troy
BAD BISH
Car: Mitsubishi Evolution VIII
Looks good kiki
"Strive for perfection in everything you do.
Take the best that exists and make it better.
When it does not exist, design it."
Kevin Troy is offline   Reply With Quote
Old 01-05-2017, 19:17   #24
markbw
markbw's Avatar
Car: Evo 6 gsr
Ahem - group buy Kiki
markbw is offline   Reply With Quote
