Evo 8 JDM Ecu Into Evo 6 Help - Mitsubishi Lancer Register Forum
Old 25-07-2019, 15:10   #1
jfed
Hey - I ended up finding a cheap JDM e8 Ecu that I'm going to put into my 6. I've been trying to match up the pins and everything seems to be ok except for the diagnostic pins from the 6. The 6 has 3 "Diagnostic" pins:
  1. 56 - Dignostics (1)
  2. 62 - Diagnostics (7)
  3. 79 - Diagnostics
The e8 ECU only has:
  1. 100 - Diagnostics
  2. 85 - OBDII
What do I plug in where? I'm confused as to what I need to do. Any info helps
jfed is offline   Reply With Quote
Old 25-07-2019, 15:21   #2
madmatt
madmatt's Avatar
Out of interest which DIY guide did you follow for the conversion?
Old 25-07-2019, 15:28   #3
grants
grants's Avatar
Not worth the effort, the cost off connectors or a patch lead is £100(ish) to £300+
if you need a later ECU look for Evo7, E8 260 or earlier USDM Evo. Thees will plug in , you'd then have to a few wires around
Old 25-07-2019, 15:41   #4
jfed
No DIY that I could find. I basically just compared the pinout for the 8 with the 6 and am swapping pins
I got the connectors from a junkyard for cheap (ECU connectors for 1999 USDM Subaru Forester) and bought a used harness extension that I'm going to cut up. It's going to be a lot cheaper than purchasing a USDM E8 ecu ($300+ in Canada)
