Evo 7 Rs Twincharged - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Marketplace > Used Car Information
Old 26-06-2019, 15:48   #1
jbakerevo
Hi Guys
Unfortunately i may have to part with the evo due to personal circumstances. I will definitely get back into an evo again but won't be for a few years.
Not sure what the car is worth as there isn't much to compare it to.
Car is on around 65,000 kilometres.
Built and maintained by Norris Designs. Twin Charged running 712bhp
ND 7R turbo kit
ND long rod drop in forged job
Wire rung head gasket and wire ring process on head
ND Intercooler and pipes
ND Supercharger kit
S90 throttle body
New K&N air filter for SC kit
ID1340 injectors
Walbro 400L in tank pump fitted and hardwired
Exedy twin plate HD clutch and bearing
Link G4+ Ecu
ND V3+ dry sump kit
ND Splittable special tank
ND Oil tank bracket
25 Row HD dash 10 oil cooler
Breather tank
Braided Hose line kit
94mm billet crank
2.24L pistons 4G63 set
ARP main stud kit
Set engine bearings
Block machining
Link Can Lambda & Uprated Knock Sensor
ND S3 Ported Head Etc +1mm and +2mm, Tiís, Springs, guides etc
TOMEI 270 11.5mm CAMS
extreme Vr2 tyres
Meister R Gt1 suspension
safety device roll cage
6 pot AP Racing front brake kit
corbeau Carbon race seat
Driveshaftshop Carbon fibre prop
Quaiffe centre diff
Driveshaft shop front and rear 900hp shafts
Gearbox recently rebuilt by clive with 4.529 final drive ratio installed
Seibon carbon bonnet
seibon carbon boot
seibon carbon spoiler
vortex Generator carbon
Very fast road going car, still has full interior.
jbakerevo is offline   Reply With Quote
The Following User Says Thank You to jbakerevo For This Useful Post:
Jim Salter (26-06-2019)
Old 27-06-2019, 09:39   #2
Draven
no price?
Organized Religion is like Organized Crime; it preys on peoplesí weakness, generates huge profits for its operators, and is almost impossible to eradicate.
Draven is offline   Reply With Quote
Old 27-06-2019, 16:54   #3
jbakerevo
Originally Posted by Draven View Post
no price?
Wasn't sure what to advertise it at. It's on ebay at £35,000. Thanks
