#1 |
![]() Join Date: Oct 2007
Car: Evo 6 Gravel Rally Car
Evo 8 Not a lot of power
Im looking for any advice I can get. Have an Evo 8 rally car with an 80 series turbo on it. Turbo is new. Boost leak test done no leaks. Compression test done 150 across the board. Leakdown test done, all good. Car is boosting to 1.4 bar. Expecting 1.8. Unable to get any more out of it. Any ideas as to what could be restricting the power?
Evo 6 Rally car and Evo 6.9 Rally car |
Sponsored Links | |||
Advertisement |
#2 |
Simon - EVO V
could it be a faulty wastegate?
#3 |
A "sock" or similar left in the air intake plumbing after the last event clean up
![]() It's been done many times Grant |
Advertisement |
#4 |
go to actuator on turbo and make sure it is pre-tensioned correctly and holding the wastegate tight shut. What actuator do you have fitted? The remove the pipe off the actuator and blank it. The accelerate carefully watching boost, see if you get more, should help narrow it down
Stu
CPP Motor Developments - CPP MLR page - CPP Facebook RG Motorsport - www.rgmotorsport.co.uk Evo 4-6 left over parts for sale |
The Following User Says Thank You to stu8 For This Useful Post: | broraboy (12-06-2019) |
#5 |
Car: JDM Evo VI GSR
Many possibilities, in my case it was a cracked turbine housing.
#6 |
Its a new Evo 9 turbo. Took the wastegate as being ok as this is second turbo with similar results. Was 1.2 bar on second hand turbo, 1.3-1.4 on new 80 series. 3 port solenoid checked and not leaking. Checked for boost leaks and ok. Grants, taken off intake pipework and no socks lol
#7 | |
As its a rally car, does it have a restrictor in the turbo setup, is the actuator and other turbo stuff as you would find on a standard evo 9? Stu
#8 |
Stu, yes there is tension, I might increase it so as to eliminate it completely. Yes im running 34mm restrictor
#9 | |
taking the pipe off the actuator eliminates boost control, allowing the turbo to give all it can, so should direct you if its a boost control issue, or mechanical Stu
#10 |
Tested car on the road. 1.75 bar. Feels like it pulls OK but not really sharp. Rollers only has it pulling 1.3 bar or so. I understand the road puts a bit more load on the transmission but surely not that much.
#11 |
sounds like a warped wastegate flapper... had a similar case.. .car was boosting about 1000 RPM late... slow spool and missing power
ACD/AYC pump repair video http://youtu.be/ZrYjQat4KGE Home built single seater, GSXR 1000 power.. ![]() My day job |
#12 |
It's brand new. Last turbo did exactly the same. It's boosting to 1.75 bar which is fine. Wonder why we can't get power on the rollers
#13 | |
https://www.lancerregister.com/showp...40&postcount=2 Stu
#14 |
![]() Join Date: Dec 2013
Car: Evo6
Exhaust ? I had a skyline once with very little boost, tried everything and eventually found it was the exhaust partially blocked due to collapsing inside the silencer.
#15 |
That was first thought. It's all clear. Strange why it boosts on the road but not on the rollers
Advertisement |
Thread Tools | |
