Monster spec evo 8 mr fq300 2.3
2K views 6 replies 3 participants last post by  Dan ep3 turbo
#1 · (Edited)
Here is my Mitsubishi Evo 8 mr fq300 in silver , it has been built to a monster spec.
Running syvecs top ecu the s8 and motorsport engine loom, has everything built into loom you will ever need. The car runs a flex fuel sensor and has been mapped with a mix of 30% ethanol so the ecu can calibrate between pure pump fuel and up to 30% mix of ethanol, was allways going to have it mapped to 90% ethanol but never got round to it.
When purchasing the ecu also ordered a heap of engine sensors to capitalise on the syvecs brilliant safety features. This includes
Bosch knock sensor
Egt sensor
Ntk wideband sensor modded for Autosport connector
Oil pressure
Oil temp
Fuel pressure
Fuel temp
Flex fuel sensor
Cal switch
R35 gtr coil kit running sequentially
Kiggly crank trigger kit
Motorsport race loom
Engine is a 2.3 and was a rosssport package
Cp pistons 85.5
Bw conrods
4g64 crank
Balance shaft delete kit
Jun 272 cams
Behive spring kit
3mm lash adjusters
Tomei adjustable pulleys
Gates timing belt kit
Kiggly hla
Reverse cam sensor kit
ARP exhaust manifold stud kit
Arp 625 head studs
ARP main studs
Acl main bearings,rod bearings and trush washers
Oem complete gasket set
New water pump and oil pump
Fluidampr crank pulley
Exedy hd twin plate clutch
Bolt ons
Hypertune inlet manifold
Hypertune 77mm throttle body
Hypertune fuel rail
Sheepish built precision 6062 vband turbo kit ceramic coated black with 4” intake and k&n air filter.
Spec-r twin breather system painted black
Hks oil cooler kit
Ross sport intercooler kit
Full 3” stainless steel exhaust
Ross sport north south bar
Torque solution engine mount
Fuelling
Asnu 1300 injectors
Twin walbro 465 fuel pump triggered by ecu one at a time
-6 feeds from tank to a y piece with 1 way valves into a -8 feed to rail with a inline fuel filter.
Flex fuel sensor.
Auromotive a1000 fpr
Chassis
New discs and pads all round
Weddsport tc105n 18x9 wrapped in nankang ns2r powder coated gloss black
Hks hipermax 4 suspension
Odyssey 925 battery relocated to boot
Evo 9 front and rear bumpers
Cusco power brace
Betrush number plate bracket
All parts have done 2k miles, just had a 4 wheel alignment carried out.the car is immaculate only marks on the body work is stone chips on front. The car has been road mapped very conservative as I never got round to getting on the dyno. The car absolutely flies and will be plenty for most people but still has lots left with a map tweak and more ethanol.i would estimate power to be between 600-700. The idle control needs some more setting up as it needs a little Rev when cold. Because of this I have priced the car at £17300, what is a bargain considering the quality of parts and all beeing as good as new
Please contact Dan on 07447457444
Located in Essex
