Why such a massive difference in price for Teins over Ohlins ? - Page 4 - Mitsubishi Lancer Register Forum
Old 17-05-2019, 23:25   #46
kikiturbo
Car: EVO 9 GSR
Originally Posted by madspeed View Post
Ohlins probably did more research than Mits. Thats all they do - suspension R&D.
...and managed to miss the spring rates on the evo 7,8,9 kit..
I highly doubt they did more work than mitsubishi on any of the two platforms..
Having said that, the R&T kit is great combo of performance and comfort, and is even better after you adjust the springs rates a bit. I have installed some 4 kits now and they work real well..
The Following User Says Thank You to kikiturbo For This Useful Post:
plip1953 (19-05-2019)
Old 19-05-2019, 02:09   #47
war-machine
war-machine's Avatar
Car: evo 7 rs
had ohlins and very good on road..wanted to try kw clubsports £2500 as mainly track work...see what there like
Old 19-05-2019, 02:16   #48
war-machine
Car: evo 7 rs
exe-tec when they released there coil over suspension ?
it was the must have kit..ohlins was not even in the running? if exe-tec started making them again ? and was same price ? would ohlins be the top daddy...i spoke to exe-tec years ago and they didnt make alot of money selling the kits...also they get their springs from faulkner who do springs
Old 20-05-2019, 13:44   #49
kikiturbo
Car: EVO 9 GSR
exe-tc concentrates on high end racing stuff,.... I doubt they will make a "budget" coilover again..
there are other systems in the ohlins price range.. like AST 5100, 5200, 5300 or Intrax
Old 20-05-2019, 15:08   #50
Jerrick L
From the physical point of view, Ohlins are Mono-tube damper while most mass market TEIN are twin-tube dampers (Tein do not do mono-tube damper until you get to the MonoFlex range).
So that is a reason for price difference.
Ohlins body are made out of alloy, Tein body are made out of steel.
The performance difference are up for debate, but there is a cost difference involved there also.
The biggest factor I would say are the internal used.
Ohlins DFV internal are much more complex, and require higher degree of precision.
They also have a lower volume so they cannot be mass produced.
Tein internal are more basic, and can be mass produced at a much cheaper price.
The question is if the performance difference is wroth the price?
In my view, yes. There are a lot of advantage a properly sorted mono-tube damper can bring to the performance table.
So if budget allows, a well sorted mono-tube damper is the base of a good performance damper.
(I say this loosely as there are high pressure twin-tube dampers like the Ohlins TTX, but those are not "common" twin-tube dampers).
In my view, if you go from the OEM Bilstein to a set of Twin-Tube Tein dampers.
It is actually taking a step back on the performance level.
Jerrick
Jerrick L is offline   Reply With Quote
The Following 4 Users Say Thank You to Jerrick L For This Useful Post:
dreMR (20-05-2019), Stallion (11-06-2019), super rover (21-05-2019), VR-4Squid (21-05-2019)
Old 11-06-2019, 12:40   #51
LiquidTension
Sorry to digress but am I right in thinking the R&T kit for CT9A comes with springs: 10k front, 8k rear?
What do you suggest in terms of adjusting the spring rates - swapping front to rear or have you found different spring rates that work better?
LiquidTension is offline   Reply With Quote
Old 12-06-2019, 06:49   #52
kikiturbo
Car: EVO 9 GSR
I have swapped them around and it is one solution, but with stiffer rear ARB that we have on that car it is a bit lively in the rear, on the road... On the track it will heat up the front tires and become nicely neutral.. I will try that car next with stock ARB and that should work well with 8 fronts and 10 K in the rear.
For my own car (this is a friends one) I am going for 8 front and 9 rear...
So, to answer your question in a shorter manner.. I would first try 8F 10R with stock rear ARB, then go fo 9K rear if that is too much. Road tires.... Slicks and track work might require stiffer springs..
LiquidTension (12-06-2019)
Old 12-06-2019, 06:50   #53
kikiturbo
Car: EVO 9 GSR
double post
Old 12-06-2019, 09:51   #54
Lolo la Torche
Senior French User
Lolo la Torche's Avatar
Car: Full Black Evo IX 600HP+
I have received 14K Front Springs for track use with slicks. I will put the 10K Spring of the front at the rear.
Stock ARB.
I'll try this this summer
Lolo la Torche is offline   Reply With Quote
Old 12-06-2019, 18:42   #55
plip1953
Phil
plip1953's Avatar
Car: Evo X 300 SST
My old Time Attack 9 used to run 16s front and rear (but they weren't Ohlins). And a 27mm rear arb. Seemed to work pretty well....
Phil
Similar Threads
Ohlins Road and Track mini-review Grant620 GB Enterprises 33 26-06-2018 13:27
Jap Spec Ohlins Price?? tofulo Suspension / Handling 2 21-08-2012 15:01
price difference EGK Lancer Chat 21 19-11-2004 13:07
