Evo 5 build 2LR or 2L - Mitsubishi Lancer Register Forum
Old 03-02-2020, 07:57   #1
zookermaa
Hi!
I just rebuild my evo 5 engine. Power target about 500hp, and main question: Are long rod or forged 2l better option. Do i need block machining if i get long rod kit? And how about pistons height it must be lower in long rod? Its that right?
zookermaa is offline   Reply With Quote
Old 03-02-2020, 10:31   #2
Arronevo8
Go long rod revs nice and less thrust on cylinder walls. No machining required on block with std throw crank.
Old 03-02-2020, 11:55   #3
Mark Shead
Car: Evo 6 under construction
If you go long rod make sure you don’t get stroker pistons and ruin your compression ratio. Seen too many done like this.
Mark
Mark Shead is offline   Reply With Quote
The Following User Says Thank You to Mark Shead For This Useful Post:
Evo6er (03-02-2020)
Old 03-02-2020, 13:38   #4
zookermaa
Okey, is this https://www.rosssport.com/Brands/CP-...COMP-RATIO-9-5 or https://www.rosssport.com/Brands/MAN...h-20l-Long-Rod piston good choice? How i can know that it is not stroker pistons?��
Mark
Evo 5
Old 03-02-2020, 14:25   #5
grants
grants's Avatar
Ask your tuner
Old 03-02-2020, 15:58   #6
Mark Shead
For best results Grant is correct you are best to get your trust tuner to sort it out for you.
First you would need to know the bowl size to know what compression you should be aiming for.
Mark
