Ayc pump repair - Mitsubishi Lancer Register Forum
Old 14-10-2020, 12:46   #1
edbowles86
Ayc pump repair
Hi everyone,
I discovered my AYC pump may have stopped working and was just wondering how straight forward it is to fix it yourself? I've seen there are some repair kits you can buy but not sure about what tools would be needed apart from the standard ones?
Is it a big issue driving with no AYC or is it simply that you don't get the benefits of it?
Also, has anyone sent theirs off to be fixed/refurbed? If so, how much does it cost?
Ed
edbowles86 is offline   Reply With Quote
Old 14-10-2020, 13:33   #2
interbishi
interbishi's Avatar
Car: EVO tme, 9gt turbo, 264,s , coilovers. CBR900
The average cost seems to be circa £500 ... my ayc pump works sometimes and sometimes not , you wont do any damage driving it .
I bought a repair kit so I will get round to it at some point .. there is a vid on youtube showing you how to do it , if you are handy with spanners give it a go ...
interbishi is offline   Reply With Quote
The Following User Says Thank You to interbishi For This Useful Post:
edbowles86 (14-10-2020)
Old 14-10-2020, 17:43   #3
r3k1355
Pump service kit here with instructions on YouTurbe.
If you want to send it out then Harry Hockly are supposed to be decent.
The Following User Says Thank You to r3k1355 For This Useful Post:
Old 14-10-2020, 23:16   #4
edbowles86
Thanks for your responses and the link to the repair kit. I think I will eventually try and have a go at doing it myself...it can join the endless list of evo related jobs
Old 15-10-2020, 14:16   #5
richyx
just hope you dont break any valves, and be careful when taking it apart, corrosion locks everything into place and being cast can be broken easily when trying to get the parts apart
only use repair kits of evolution hydraulics
harry hockely use alloy plates not stainless so eventaully will have the same issue again later on
my resto thread
richyx is offline   Reply With Quote
The Following User Says Thank You to richyx For This Useful Post:
edbowles86 (15-10-2020)
Old 15-10-2020, 14:19   #6
richyx
one thing i hate when doing them is when other have had a go and completely destroyed the pump lol
just take your time with it
my resto thread
Old 15-10-2020, 20:37   #7
edbowles86
Do you think they should come apart easily enough if the three long bolts that connect it all together are cut at the head? I'm fairly limited in terms of tools - just have wrenchs, flat head screw driver to pry it apart and a dremel to cut.
It seems from the videos, that they normally fail due to how much corrosion builds up.
Thanks again for all the advice
Old 15-10-2020, 22:46   #8
fozz57
Car: Ralliart Sportback
The pump on the Sportback had to be repaired last year. The casing was corroded solid and eventually had to be sorted by Auto Torque.
Not cheap but repaired.
Good luck
Brian.
fozz57 is offline   Reply With Quote
Old 16-10-2020, 05:54   #9
kikiturbo
Car: EVO 9 GSR
the long bolts usually corrode the whole length. The later pumps are tough to open...
ACD/AYC pump repair video
Old 16-10-2020, 16:42   #10
richyx
sounds like a x pump, therefore good luck lol, as chop head off your then left with flush bolts inside the centre housing that are also corroded inside
my resto thread
Old 13-11-2020, 16:11   #11
Jim Salter
Is Harry Hockley operating at the moment?
Have sent an email, used the web form on the website, have sent a Facebook message and called the number but have had no reply
Jim Salter is offline   Reply With Quote
Old 13-11-2020, 19:12   #12
Baileyk
I sent an email 2 months ago. No reply either.
Baileyk is offline   Reply With Quote
The Following User Says Thank You to Baileyk For This Useful Post:
Jim Salter (13-11-2020)
Old 13-11-2020, 21:45   #13
edbowles86
Do you think it's quite a mission to repair it yourself? I was planning on trying soon with this
https://www.evolution-hydraulics.com...ir-service-kit
Old 13-11-2020, 23:12   #14
kikiturbo
Car: EVO 9 GSR
it depends on the valves being broken or not
The Following User Says Thank You to kikiturbo For This Useful Post:
edbowles86 (14-11-2020)
Old 14-11-2020, 09:35   #15
Jim Salter
Also if someone had repaired the pump before and cut way too much of the motor edge off ☹️
The Following User Says Thank You to Jim Salter For This Useful Post:
