We have supplied several Safety Devices cages over the last couple of years.
Its a great product, MSA approved, and the quality/fit is always perfect.
A very convenient way of adding additional safety to your circuit or sprint car without the need for a permanent 'weld in' solution. Making it easy to either return your car to standard road going spec should you sell it or upgrade.
Please also note that we have all SD cages available from stock including the weld in cages for Evo 4-9.
Most people either get a pro to fit start to finish or fit them selves.
You need to put the cage in bolted up losely before you can tack the feet, so you are 1/2 way there with the fitting.
Full fitting would be 6-8 hours work.
Due to demand, we ordered another 10 cages, so there will be about 6 that aren't sold. Which will be available from stock. Contact us with your requirements :thumbup:
1) Any pics of these fitted to a 7/8/9 showing the rear compartment? (i.e - how usable the rear seats are)
2) I can't get my head around the rear cage options, any pics of different ones?
Would you please enlighten me, as to the names of the parts I have highlighted? I can't see any diagonal (unless its the part between the rear arches)
Which is the harness bar?
The other batch of cages has gone today guys, so if you didn't get yours today, it will be Monday by TNT. As a matter of course. Please sign for all cages as DAMAGED, even if they are not damaged, we will be unable to peruse any claim for damage unless this is done.
Plenty more cages available from stock if anyone needs one
Related Threads
Lancer Register Forum
5.7M posts
86.3K members
Since 1999
