hello from France: My 450WHP Evo IX - Page 11 - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Picture & Video Gallery
Thread Tools Rating: Thread Rating: 26 votes, 4.96 average. Display Modes
Old 13-03-2017, 14:50   #151
Lolo la Torche
Senior French User
Lolo la Torche's Avatar
Car: Full Black Evo IX 600HP+
Yes, I was mailing you
It didn't fit, it touches the turbo and it "bend" the arm
I will maybe try the change the spring, it is probably the easiest mod
Edit: when we push some air in the WG, the arm moves but we can see the turbosmart fixation bending...
Lolo la Torche is offline   Reply With Quote
Old 13-03-2017, 14:52   #152
Lolo la Torche
Senior French User
I didn't get the car to a dynamometer, either with HKS and EFR. I just can estimate comparing to other evo IX, so, I don't talk about figures as it could be easily challenged
The Following User Says Thank You to Lolo la Torche For This Useful Post:
Mita (13-03-2017)
Old 13-03-2017, 15:42   #153
phedV
Car: E90 320d M Sport
You might need a thread title update:
Cool car btw hope it performs as you expected!
phedV is offline   Reply With Quote
Old 13-03-2017, 15:59   #154
Lolo la Torche
Senior French User
I had a powerdyn estimation (550HP) but not as reliable as a dynamometer
550Hp is 450whp with a 18% loss, so...
I do think that the conf is now 550/570hp and 65/67 mkg. But no proof, no figure and don't want any controversy
Edit: figures running E85+methanol
Old 13-03-2017, 19:57   #155
alpinaturbo
Time to put some pump fuel and run it again, so we can see what is going on.
Why Ethanol and Methanol mixed? That is unusual.
The figure of 450whp on E85 is about right what I expect: what boost (2Bar or )
Congratulations - its a rocket for sure.
What RPM do you get 1Bar of boost? Minimum in 4th gear for example?
alpinaturbo is offline   Reply With Quote
The Following User Says Thank You to alpinaturbo For This Useful Post:
Mita (13-03-2017)
Old 13-03-2017, 20:27   #156
Lolo la Torche
Senior French User
1bar @ 2800tr in 4. Can't do better than 1.8b in pic (impossible to go to 2B)
I run ethanol as fuel and methanol in a Motec Driven aquamist (noozle in piping)
I'll try pump fuel in a few month when we will set the SP98 conf
Old 13-03-2017, 22:58   #157
Lolo la Torche
Senior French User
Setup update N°2541547
Motor:
Ross (Magnus) Specs X 86mm forged pistons
R&R long Rod forged rods
Balanced Crankshaft
ACL Race Bearings
Cylinder head gasket HKS 1.2mm
ARP Head Studs
Map Performance strengthened screw and gudgeons
Maperfomace Valves
[strike]Map Performance Exhaust manifold (black coating)[/strike]Full Race Manifolm with 4 lambdas 2 EGT and 1 counterpressure bungs welded
Full décata Milltek 110 exhaust
[strike]Invidia Elbow (with mods)[/strike] Full Race Flex Down Pipe with Lambda mod
Matte black powdercoated black Heatshield for Camshafts sensor Gold tape isolated
Walbro 455 fuel pump
Direct wiring for fuel pump with relay
Injector Dynamics 1300cc injectors
Fuel Rail AMS
Fuelab Fuel pressure regulator
ETS 3" Intercooler
2,5" ETS Short route piping matte black powdercoated (modified to accomodate new turbo)
ETS silicon kit
Grimspeed solenoid
HKS Kansai carbon airbox (Modified to accomodate Evo 6 radiator and hose)
HKS carbon cooling panel
AMSOIL air filter
GSC2 Camshaft
GSC springs with titan spring plate GSC "11 000 rpm"
Hydraulic 3mm lifters
[strike]HKS 7460 GTII KAI HKS with Turbosmart 18 PSI wastegate actuator[/strike] BORG WARNER EFR 7163 Twin Scroll T4 Turbo Kit
Turbo Speed sensor
Alloy internal dump cover
Turbosmart 75 Wastegate Twin Port actuator
Turbo Heat Blanket
AMS Moroso anti starvation wet oil sump (big capacity gold tape isolated
NGK RACING "Cold" spark plugs (8 for road use, 9 for track use)
Battery Trunk relocation Kit "Evolutions Solutions" from Neverneverman
Yellow Optima battery
3 poles circuit breaker
APS Dump valve
JMF Mini Oil Catch Can JMF matte black powdercoated
Home made MAF suppressor matte black powdercoated
Hell Performance 25 rows Setrab Kit (black)
Matte black powdercoated Radiator bracket
Evo 6 water radiator
Revotec Comex high speed Fan (with OEM fan module)
Air temp sensor
Boost sensor
EGT sensor
FlexFuel sensor
MOTEC M800 Ecu
MOTEC UTC
MOTEC SLM
Plex Tuning µsdm 102 Pro Version
Aquamist HSF3 with 2 jet (1mm+0.9mm) driven by Motec (100% methanol)
Howerton trunk trank special Methanol Kit
Transmission
Exedy two discs clutch
Steel durit for transmetter and receiver
Locking release bearing kit
Brakes
Master cylinder stopper GL Racing matte black powdercoated
Front and rear lines Goodridge
RBF600
Full Race Alcon 365mm front Kit
Full Race Alcon 330mm rear kit
Fully floating front Alcon rotors
Floating (with handbrake) rear Alcon rotors
Modified rotor heatshields
pagid RS29 "yellow" pads (rear and front)
Home made Brake Coolers
Frame
Cusco Front Center Underbody Power brace
Cusco Lower Arm Bar
Cusco Strut Bar
Front Strut Brace Ralliart Aluminium matte black powdercoated
Rear Strut Brace aluminium Ralliart matte black powdercoated
Ohlins DFV Road and track Dampers
Whiteline Roll center correction Kit
Infra silent bloc BLOX
Team Dynamics Race 1.2 18*9 ET30 with 230mm Yokohama A005 Slicks
****pit&interior
ColtSpeed Console Mano Carbon (Carbon look)
DSD Manometers (oil pressure, oil temp turbo boost)
Autometer Carbon Aquamist control and gauge holder
Aquamist gauge "red LED model"
All plastic parts painted in Mitsu Black
Schroth ASM Flexi II black 6 point harness with flexibelt option for driver
Schroth ASM Flexi II black 4 point harness with flexibelt option for passenger
Ralliart shifter Aluminium
Ralliart aluminium footswitch
Recaro seat belts sleeves
Recaro Pole Position leather and Alcantara buckets
Recaro side protectors
Buddy Club superlow rails
Matte Black professional custom made half cage
MOTEC shift light
Flocked dashboard
Leather ("turned skin") OEM Streering wheel with red Topstitching and red central mark
door pass carbon Mitsubishi
Exterior
Vortex Mitsubishi
Perrin short antenna
Back emblem carbon
Black logo » Evolution MR »
Front Logo 3 diamonds paint in black
Smoked indicators
Tainted glasses carbone dark
Orange indicators bulb
Home made hook relocation bar with TRS black towing belt
The Following 3 Users Say Thank You to Lolo la Torche For This Useful Post:
alpinaturbo (02-04-2017), evolover21 (02-04-2017), RichW (15-03-2017)
Old 15-03-2017, 11:58   #158
kikiturbo
Car: EVO 9 GSR
shame, looks like the clocking on the turbo on full race manifold is different than on mine.. on my manifold works fine
The Following User Says Thank You to kikiturbo For This Useful Post:
alpinaturbo (16-03-2017)
Old 16-03-2017, 06:07   #159
alpinaturbo
I am stoked by your EFR Fit - with no drawback for WG, and by the quick spool - 1Bar at 2800rpm is pretty amazing.
My HKS achieves 1bar by 2900rpm, and 16psi (1.1Bar) by 3000rpm.
I think 450whp at 2Bar to 2.2 bar is entirely possible and likely: hope to see the same.
Old 16-03-2017, 08:19   #160
Lolo la Torche
Senior French User
I can't exceed 1.8b at that time. I will try to find why later
Running [email protected] offers enough power (probably 450/470whp) and a huge range.
Too many people on the road to make a good log nowadays
kikiturbo (16-03-2017)
Old 27-03-2017, 13:29   #161
Lolo la Torche
Senior French User
I want to delete the complete assembly of my APS dump valve. The turbo has its own, and Least plumbing we have, least risk of leaks or problems we have...
I look for some caps to plug the holes. A 35) mm female one, a 35mm male one And a little "vaccum" one.
Where could I found them? (with dedicated clamps)
Old 02-04-2017, 17:56   #162
alpinaturbo
Laurant,
Am curious about the change in power moving from HKS to EFR7163:
Since you run E85 & Methanol, its hard (for me at least) to estimate the difference before & after the turbo swap.
Typically HKS is considered 470bhp turbo, with pump fuel dyno like VD and DJ reading about 410whp.
Your EFR is clearly pushing in the neighborhood of 550bhp, 450whp-470whp as you estimated- but this figure is an estimate on E85+Methanol, while HKS 410whp DJ/VD is on pump.
Can you please put the two turbos in prospective- what do you "feel" or have somehow measured to be the difference?
You are measuring backpressure?
If you are can you tell us what is backpressure at 1.8Bar?
Thank you Laurant.
Your car sure is beautifully developed, the orange wheels really look cool on black.
Old 02-04-2017, 18:53   #163
Lolo la Torche
Senior French User
thank you for the compliments
TBH, I think that the performance difference between the 2 turbos is very minimal.
When we tuned the EFR (@E85 but without meth), we didn't have to modify the richness. No need to add some fuel...So, the power is the same...
So the real gain is that it took a little more boost and that it keeps it a little longer @ high revs.
The feeling when driving them is the same ;à Great spool, utra responsive!
I have discuss several times this week with Geoff. He thinks I have a bit of backpressure (I don't measure it)
I have a 26PSI turbosmart actuator, but the off mode "only" reaches 20/22 PSI. So, I need to try to retension a bit the actuator arm and see if it helps.
Anyway, my HKS was absolutely overrage and was beggining to die. The EFR is only 118000rpm, but 150000rpm capable, so there is a huge fiabiliy improvement
Old 02-04-2017, 19:25   #164
alpinaturbo
Thank you Laurant.
Very interesting what you are saying, similar power and response.
The Fuel-Adjustment was not necessary because you did not exceed the flow-rates previously achieved by use of the HKS.
So if I read correctly: you only run 20-22psi max?
And on HKS you ran 25-26psi or more?
I mean, on E85 (& Meth) you can run HKS to 30psi.
I am curious if actually the EFR7163 achieves much lower maximum-boost due to actuator issue, than HKS, but fueling does not need modification?
For sure EFR will be able to push more top end boost.
The Backpressure - Miltek 110 Decat full exhaust does not present any chance for backpressure.
Please tell me what boost was HKS running at, and what actual boost is EFR7163 running at ?
(1.8 bar is 26psi you mentioned earlier, but than you talk about 20-22psi only).
Thank you
Old 02-04-2017, 20:02   #165
Lolo la Torche
Senior French User
No, I mean that min Boost is 20-22 PSI (WG spring is 26). But i run 26 PSI "stabilized" with a short 29 PSI peak.
Was running same boost with the HKS. Neverbe able to reach 30PSI
As the turbosmart WG spring is 26PSI, but on "off mode" (0 solenoid duty), I just reach 22PSI, I think I have to retension he actuator arm. According to geoff, 6mm more.
I think the counterpressure comes from the turbo housing, not from the 76mm Milltek
Similar Threads
Model Differences / Specifications youngsyr Lancer Chat 238 09-10-2019 21:15
Stolen Evo's marksmart Lancer Chat 309 28-11-2017 08:42
Sti or evo 6 Bakerboy Lancer Chat 42 12-08-2011 19:11
Evo 5/6 Breaking parts full parts list itemsfrom £6 Xenonshop Private Sales - Parts 120 03-06-2011 11:06
LED Side & Foglight Group Buy from Xenonshop BHP MLR Group Buys 576 30-03-2011 12:05
