Garage damaged my subframe should I have to pay for it? - Page 5 - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Lancer Chat
Old 11-01-2020, 17:21   #61
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
1 tip also, when the garage has stripped the underneath, and cleaned off all the crud, paint, protective layer, and rot, go look at whats left, where they are going to weld from, you may just find you are ending up with a patch job, welded to what remains of original metal which is likely also corroded, and have a good look, see if the money you are throwing into the restoration is firstly going to be enough of a repair, and if it is, is that going to be job done for now, or will it be getting more welding in the near future. Far too easy to throw money at patching and fall into a position where so much has been spent already you have no option but to keep going
Stu
The Following 2 Users Say Thank You to stu8 For This Useful Post:
evo5d (11-01-2020), Mita (11-01-2020)
Old 11-01-2020, 17:29   #62
big S
Originally Posted by Evo(v) View Post
Another mechanic that doesn't understand how tools are used
Perhaps you could tell us at what point in the video the tool was used to REMOVE the bolt like you claimed?
Evo 7 fq Mr 260!
big S is offline   Reply With Quote
The Following User Says Thank You to big S For This Useful Post:
Mita (11-01-2020)
Old 11-01-2020, 17:49   #63
Mita
I’d personally like to thank you. This is the best thread on here in ages.
Aluminium is higher up the emf chart so steel corroded not the aluminium, the aluminium subframe will not have been weaken by any sort of corrosion at all, suppose I'm being argumentative for pointing this out, could care less that the bolt got corroded n stuck as my point right from the beginning of the thread was to sacrifice a cheap bolt
The Following 5 Users Say Thank You to Mita For This Useful Post:
ant1 (03-04-2020), big S (11-01-2020), evo5d (11-01-2020), Tom Dick (11-01-2020), woodywoodpecker (11-01-2020)
Old 11-01-2020, 18:01   #64
cheeseface39
Do you reckon the op knows how many red tme,s where built
cheeseface39 is offline   Reply With Quote
The Following 3 Users Say Thank You to cheeseface39 For This Useful Post:
big S (11-01-2020), LEGNUMVR4 (11-01-2020), Mita (11-01-2020)
Old 11-01-2020, 18:05   #65
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
Another mechanic that doesn't understand how tools are used needs a step by step, it cut through those items like butter if you can't figure out how you could use that to remove either end of the bolt or cut a slot out of the nut to release grip or cut down the inside of the frame through the bolt then not much more I can say is there really?
I've only used mine to remove 16mm 20mm bolts on site, **** knows how I pulled it off now, you lot are starting to make me feel superior, I'm literally talking to people that can't for the love of money figure out how they could remove that easily accessible bolt and trying to tell me the aluminium subframe had corroded, unreal
seriously pal you need to get you head out your backside on this one
your WRONG ,yes you can use a multi tool to get the bolt out ,no bother ,but NON of us would if they hadnt have tryed a spanner before hand ,which the bloke whos doing the work on you car has ,but since the subframe is in a bad way in that area ,its a known comman issue on earlier cars, its snapped off ,no ifs no buts ,the bolt is a welded washer cam bolt to allow you to adjust the geometry on the rear end ,if its seized ,which it has it would place even more stress on weak bit of aluminuim ,there for its only escape is to snap whats been snapped off
some of us on here have been taking these cars apart for all most as long as they have been coming in to this country ,to comment on something youve absolutly no idea about isnt making you look superior ,infact quite the opposite
The Following 8 Users Say Thank You to super rover For This Useful Post:
ant1 (03-04-2020), Coggy (16-01-2020), evo5d (11-01-2020), Evo6er (11-01-2020), interbishi (11-01-2020), M11LHR (12-01-2020), Mita (11-01-2020), stu8 (12-01-2020)
Old 11-01-2020, 19:38   #66
Mita
I reckon he drives a Honda Jazz
ant1 (03-04-2020)
Old 11-01-2020, 20:50   #67
Aidy
Aidy's Avatar
Car: Yellow EVO X
Ignorance? So because I point out a few facts I'm accused of ignorance and being argumentative!
I was alluding to what I assume would be four pages of bad legal advice, I wasn't commenting on you at all.
guess you never used a spanner before
Oh, God no.
Aidy is offline   Reply With Quote
Old 11-01-2020, 21:52   #68
kikiturbo
Car: EVO 9 GSR
Aluminium doesn't corrode....
The Following 2 Users Say Thank You to kikiturbo For This Useful Post:
big S (12-01-2020), super rover (12-01-2020)
Old 11-01-2020, 23:31   #69
Mikeb1984
Mikeb1984's Avatar
Car: white 9 GT
Off topic my apologies op. But who was the Honda jazz guy? Brings back so many fond memories!
Evo 9 GT
Mikeb1984 is offline   Reply With Quote
Old 12-01-2020, 06:54   #70
big S
Just going of memory. He was the bloke who kept saying he was gonna buy a x then didnt. Mid 40's virgin lived with mum and drove a jazz. (Cant remember user mane)
Evo 7 fq Mr 260!
Old 12-01-2020, 07:09   #71
Mita
Mal X
The Following 2 Users Say Thank You to Mita For This Useful Post:
ant1 (03-04-2020), big S (12-01-2020)
Old 13-01-2020, 02:05   #72
Evo(v)
Evo(v)'s Avatar
Car: Standard evo iv
While cant you imagine the frame with the arm and bolt still in, cut either side the arm will drop to the floor, or if you have the subframe already removed it can be pulled away
Mitsubishi lancer evolution iv 1996, Scotia white
Evo(v) is offline   Reply With Quote
Old 13-01-2020, 02:07   #73
Evo(v)
Evo(v)'s Avatar
Aluminium*offers a rare combination of valuable properties. It is one of the lightest metals in the world: it's almost three times lighter than iron but it's also very strong, extremely*flexible*and corrosion resistant because its surface is always covered in an extremely thin and yet very strong layer of oxide film
Old 13-01-2020, 02:22   #74
Evo(v)
Evo(v)'s Avatar
https://www.aluminum.org/strength-aluminum
Works on a couple of evos knows everything about the properties of metals except everything said is wrong, if you can, read that it isn't very long
Aluminium doesn't weaken with age some of the tallest skyscrapers use aluminium a lot older than our cars, planes! Ships etc, sound like the type that will argue black is white realise your wrong but carry on, if I'm wrong I'm more intrigued and I want to learn more, I admit when I'm wrong but so far I have found no evidence of aluminium cording or getting weaker, you even made me doubt what I learned at college for a moment
Old 13-01-2020, 02:24   #75
Evo(v)
Evo(v)'s Avatar
My other car is a dacia sundero
