Does EvoX SAYC fit an Evo6 - Mitsubishi Lancer Register Forum
Old 06-05-2020, 06:19   #1
nikjt
Car: Evo 6 Tarmac rally car, caged, MCA suspension, Pirelli Trofeo R tyres on Enkei WRC Evo
My AYC squarks like a parrot, so I'd like to change it out for an SAYC unit, I have found a diff from a EvoX SST, which I believe is SAYC, but trying to work out if it will be a direct replacement for my standard AYC unit.
I believe I just have to change over the input flange.
Can anyone confirm this fitment?
Any info much appreciated, thank you
Nik
Nik
nikjt is offline   Reply With Quote
Old 06-05-2020, 10:41   #2
djmisio85
djmisio85's Avatar
Car: Lancer Evo 2 RS
Have you tried replacing the fluid in the clutch pack oil chamber? This worked for me on my 5 recently (awful grinding and squawking, the mitsu dealer told me I need a new diff... idiots)
Someone correct me if Iím wrong, but I think the evo 10 rear diff casing will need a bit of modding to fit your 6. The 7,8,9 diffs will all fit as a straight swap, but you wonít get the full benefit of the s-AYC on the 8&9 diffs.
djmisio85 is offline   Reply With Quote
Old 06-05-2020, 22:07   #3
nikjt
I'm not certain of the comment about getting the full benefit of SAYC, but what I will get is the benefit of improved torque transfer due to the planetary gears in the SAYC diff ILO of the open diff in a early AYC, which is the full point of changing it to this and seems like a reasonable performance improvement.
Obviously the 6 doesn't have ACD, but that's not what I'm looking for, just the best rear diff I can with a performance improvement, without the full cost of an RS diff.
I have tried replacing the fluid, only once mind you, and it still squarks, although clearly still operational.
I first cooked the diff on a 55km twisty tarmac rally stage, and wonder if the clutch packs are now damaged.
Nik
Old 07-05-2020, 09:04   #4
r3k1355
There are two fluids to change aren't there? Clutch bath and diff oil?
I assumed you've tried bleeding the system to check for air?
The Following User Says Thank You to r3k1355 For This Useful Post:
djmisio85 (07-05-2020)
Old 10-05-2020, 12:50   #5
Wertigo
Nik
you will not be able to put the AYC from EVO X to Evo 6 drive shafts are different in the spline part. there are also different flaps on the main pair . you will also have a big problem with the gear ratios as they are very different . we put the SAYC from EVO 8 to EVO 6 the result is the gearbox fell apart after 200 km when driving calmly
Wertigo is offline   Reply With Quote
