Anyone know anything about CCTV? - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > General Stuff > Non-Lancer Chat
Old 16-12-2019, 17:38   #1
denboy
denboy's Avatar
Car: EVO 10 (sold) MK3 RS Focus, Suzuki swift (wifes)
I have ctronics cctv with 1tb hard drive. I want to transfer some files to a usb for a neighbour (5 days worth) but when I insert a 4tb usb drive or 128gb usb drive, it says there is not enough room on the drives. I'm confused.
denboy is offline   Reply With Quote
Old 17-12-2019, 07:39   #2
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
dont know anything about this really, but have the portable drives been formatted, and to the correct format?
Stu
Old 17-12-2019, 07:47   #3
denboy
denboy's Avatar
Stu
They were formatted, I tried them on both FAT32 and NTFS.
The Following User Says Thank You to denboy For This Useful Post:
stu8 (17-12-2019)
Old 17-12-2019, 14:02   #4
david_smith_909
Car: E6
Not familiar with this particular CCTV but firstly you will need to cut the videos, the box should be able to do this itself, the file size is normally limited to less than 4gb, regarding the formatting of the usb again normally the CCTV system will do this.
On mine if I select a couple of cameras and the time stamp it will split up the videos into multiple videos while converting it to a video format that all devices can read, then if I plug in a usb and go to external storage on the box it will always tell me the system wants to format the usb before it will back up the media to it.
Hope this helps
*Edit to add, both my old setup, new setup and a neighbors are like this, all different brands and age, so good likely hood yours will be, it does all this when I go to the 'backup' or 'backup to external storage' options. It will format the usb first then ask what cameras and what time frame you want backing up (so reverse what I said above )
Sent from my Pixel 4 using Tapatalk
VI GSR - SOLD
B8 Audi RS4
david_smith_909 is offline   Reply With Quote
The Following User Says Thank You to david_smith_909 For This Useful Post:
denboy (17-12-2019)
Old 17-12-2019, 14:46   #5
denboy
denboy's Avatar
Hope this helps
I'll give it a go, I was only wanting to back up one camera. Ta for your help.
Old 17-12-2019, 15:35   #6
r3k1355
NTFS usually isn't recognised by many devices, it's more for Windows.
Fat 32 has a file size limit that can get problematic with large videos.
Format with ex-FAT thats well used but also less of a problem.
The Following User Says Thank You to r3k1355 For This Useful Post:
denboy (17-12-2019)
