Evo V forged long rod - Mitsubishi Lancer Register Forum
Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 06-05-2015, 10:31   #1
HOW5ER
I've not long bought this fantastic machine but it just doesn't get used like it should and to be honest gets in the way (Especially with 3 kids) When I get a bigger house with a double garage and the kids have grown up a bit then it would be perfect but at the moment its just not ideal.
The car is very clean and solid, Has never seen a winter road and is very well wax oiled, Only slight issues would be some very minor cosmetic marks, But for a car this age it is in fantastic condition.
The engine is fresh with all oils and belts done, The car drives immensely and is ready for the summer blasts with nothing needing done.
Silver Evo 5 Imported June 2009 by S G imports, I am only the second owner.
It had 66680km on the odo and now has 97k ish
Shell, interior and Bodywork
GSR shell standard in Satellite Silver with RS front Bumper,
Standard interior is complete with no tares marks etc
This one has climate control, which is ice cold!!
Bodywork is good and straight with only some slight stone chips and minor scuffs.
The whole car is poly bushed with EVO 6 rear alloy suspension arms, no extra gauges apart from originals.
Alpine CD/MP3 player fitted with I-pod connection, Rockford Fosgate punch speakers all round with separate tweeters in the front
Engine/Transmission (Engine has about 3000miles on it)
Engine is a 2.0ltr long rod built by Evotune to Jamie’s spec at 95k in 2015,
Standard EVO 6 block/head,
BC titanium spring caps and BC springs,
272 Kelford cams,
Adjustable pulleys,
kigley oil pressure restrictor,
AMS alloy plug cover.
Block has had balance shafts removed,
crankshaft balanced and micro polished,
new oil pump,
water pump,
tensioner kit,
gaskets,
cp pistons,
BC H beam rods,
MR head gasket,
ARP main and head bolts etc.,
AMS alloy winged sump with baffle plate and crank scrapper, Standard inlet manifold/throttle body etc
1000cc injectors,
340lpm fuel pump (hard wired).,
4 branch thick walled exhaust manifold,
Evo 9 turbo with 20g wheel and ant surge housing,
large intercooler (toyo sport),
24row oil cooler,
evo9 dump valve etc. etc.
Turbo manifold,elbow and front pipe are C-tec 3” modular bits with a silenced d-cat
HKS super Drager fitted front to back (100dbs at last sprint)
Made 440HP on the rollers running on 95ron at 1.7bar and the world’s safest map!!! Should do 500hp mapped up no probalems, with it being a long rod the higher you rev it the more power it makes!!!!
Drivetrain
Exedy twin plate clutch with recent new plates fitted.
Standard evo V GSR gearbox in perfect working order.
Evo RS transfer box with helical front Diff (uprated bolts fitted)
Hardened gearbox output shaft (recardo shaft)
Rear RS diff kit fitted
Chassis
Coilovers are Gaz Gold with adjustable dampening and height with 700lb/500lb springs and White line rear ARB
Wheels are 5 spoke Evo IX 17" speedlines in mint condition with AD05 yokahama tyres fitted.
Brakes (These have some very serious stopping power) on front are K-Sport 8pots with nearly new discs and ½ worn pads, rear are standard Brembo with recent PFC pads.
ECU
Evo 9 ecu running speed density
Since buying the car I have,
Changed the oil (Gulf 5w 40 racing oil) and Mitsu filter,
Had the interior out and cleaned and the seats shampood,
Polished some bits that needed attention on the body,
Fitted new Rockford Fosgate speakers and tweeters to compliment the Alpine head unit.
Had the front bumper rubbed down and painted.
The car comes with some boxes of spares, drive shafts, door handles, wing mirrors etc etc, Also with a brand new 5L drum of Gulf racing oil and a brand new Mitsu oil filter
Serious enquiries only please, Priced at £10k
Car is in Elgin, My emil is [email protected] or you can PM me here if you are a member.
Sorry for the crap pics, Ive just not had tome for a detail or to take some decent pics.
URL=http://s721.photobucket.com/user/how5er/media/Evo%20V/20150602_165226_zpspa5mlm2t.jpg.html][/URL]
Silver forged V, FP Green, RS diff, Gaz golds, K sports....
HOW5ER is offline   Reply With Quote
Old 06-05-2015, 10:38   #2
HOW5ER
Some old pics taken from before I bought the car and some after I bought it, I have removed all the stickers from the tail.
[/URL]
The Following User Says Thank You to HOW5ER For This Useful Post:
evo_ali (29-05-2015)
Old 06-05-2015, 13:00   #3
Panjy
Car: Evo 9 FQ340
That looks really nice, do you have any interior pics?
Panjy is offline   Reply With Quote
The Following User Says Thank You to Panjy For This Useful Post:
HOW5ER (06-05-2015)
Old 06-05-2015, 21:22   #4
andyctr
Really like this.
What the MOT on it.
andyctr is offline   Reply With Quote
The Following User Says Thank You to andyctr For This Useful Post:
HOW5ER (06-05-2015)
Old 06-05-2015, 21:29   #5
Mr G
Mr G's Avatar
Car: Evo 6RS
Yhpm
Mr G is offline   Reply With Quote
The Following User Says Thank You to Mr G For This Useful Post:
HOW5ER (06-05-2015)
Old 06-05-2015, 22:13   #6
HOW5ER
Ill get onto the pics in the morning mate, Interior is mint!! Everything works exactly how it should, No tears or bad wear, All pixels on digital clocks work and air con is ice cold
Old 06-05-2015, 22:21   #7
HOW5ER
Originally Posted by andyctr View Post
Really like this.
What the MOT on it.
It looks better in the flesh mate and goes even better, MOT is till August the 7th 2015, Bearing in mind it was last MOT'd with 94k and it now has 97 something on the clock.
Old 07-05-2015, 18:17   #8
andyctr
Right.thanks.would you be willing to put a fresh MOT on it?
Old 07-05-2015, 18:19   #9
andyctr
Is the drivers side wing a slightly darker colour?
Old 07-05-2015, 18:42   #10
Mita
Go and see the car fella ^ !
HOW5ER (07-05-2015)
Old 07-05-2015, 19:48   #11
HOW5ER
It certainly not a different colour mate, Its just the angle of the photo
Yes Id certainly MOT if I got a deposit or knock a few quid off the price.
Old 07-05-2015, 20:06   #12
HOW5ER
Some interior pics, Apologies for the messy carpets, my cars are usually mint 100% of the time!
Old 28-05-2015, 12:52   #13
HOW5ER
My 3 weeks offshore is coming to an end on Tuesday for anyone that was interested to view etc,
Ive just got some new reg plates ordered and am getting the front bumper painted non the 29th of May, Really looking forward to getting onto dry land and getting this thing out on the back roads
May part ex for something with 2 wheels
Old 05-06-2015, 22:58   #14
christaylor evo
Got 9k here if thats any good
christaylor evo is offline   Reply With Quote
Old 06-06-2015, 13:30   #15
turboloon
emailed ye fella..
turboloon is offline   Reply With Quote
