Abs code 63?!?! Random- flashes but no abs light on... and AYC codes for good measure - Mitsubishi Lancer Register Forum
Old 07-01-2020, 19:24   #1
Lovinit
Junior User
Hey guys - need some diagnostic one fault finding please...
Evo 6
I have codes 41 & 82 on the AYC light -
Driving the car the AYC light would turn on after a long drive- I noticed this last week... this week tho it’s been coming on quicker and quicker ... so I decided to check the OBD! I did the pin trick and counted the flashes and got the above readings for the AYC light... I haven’t even had time to figure out what they are n how much it’ll cost to fix
But I noticed the ABS light flashing... n it’s code 63 ?!? The abs light has never come on in my ownership... but it’s odd that it’s flashing that the abs - ecu needs replacing??
Any advice on this situation or any of the above situations would be helpful!
Thanks very much
James
Lovinit is offline   Reply With Quote
Old 09-01-2020, 07:02   #2
Ads9
Ads9's Avatar
Car: EVO IX FQ320, 2.2 Cosworth, TT S214b, Link G4+ Geekmapped by me (hasn’t gone bang. Yet.)
https://www.lancerregister.com/showthread.php?t=431054
I'd say ABS ECU is failing given that's what 63 is meant to indicate? Have you checked the plug on the front of the ABS pump/ ECU is secure. Maybe remove, check the pins and refit first.
Ads9 is offline   Reply With Quote
The Following User Says Thank You to Ads9 For This Useful Post:
Lovinit (11-01-2020)
Old 11-01-2020, 06:01   #3
Lovinit
Junior User
Thanks for your reply...
Will try this this weekend... been a little busy last couple of days With the work
I guess the code is telling me something lol...my concern was for the fact it doesn’t show up on normal start up... if the abs was failing surely on a day to day the abs light would come on... I guess I was hoping it was linked to something else
Cheers ... keep u posted 🤞
