help parts needed for evo 6 - Mitsubishi Lancer Register Forum
Go Back   Mitsubishi Lancer Register Forum > Marketplace > Wanted
Old 09-03-2014, 15:47   #1
evosmudge
evosmudge's Avatar
Parts needed
Cambelt sensor
Crank shaft sensor
Cam sensor
Camshaft sensor
Cambelt tensioner
Balance shaft belt kit
Inlet maifold bolts
Exhaust maniflod bolts
Flywheel bolts
Turbo to sump pipe and gasket
Oil filter housing
Rocker cover cam rota sensor
Coilpacks
Cambelt cover complet
Lower main pully
Water pump pully
Altinator tensoner
Throttle body control valve
Engine anf gearbox bolts engine and gearbox mont bolts
Sas
Metal plate for engine and gearbox
evosmudge is offline   Reply With Quote
Old 09-03-2014, 17:20   #2
adamfitz
Got some coilpacks mate and I'll also have the std oil return very soon
adamfitz is offline   Reply With Quote
Old 10-03-2014, 16:56   #3
Xenonshop
Car: Mitsubishi Evo VI
i have a water pump pulley n metal plate between engine and box
Xenonshop is offline   Reply With Quote
Old 10-03-2014, 17:15   #4
eagle-evo5
Car: L200 Animal
I have;
Cambelt tensioner
Inlet maifold bolts
new M8 Exhaust manifold studs
Flywheel bolts
Oil filter housing
Water pump pully
Altinator tensoner
Evoless
My Feedback Thread >>> https://www.lancerregister.com/showthread.php?t=450897
eagle-evo5 is offline   Reply With Quote
Old 12-03-2014, 17:44   #5
evosmudge
evosmudge's Avatar
Thank u for your messages in the end I have had to get another engine as the one I bought was nackered.
