Mitsubishi Lancer Register Forum
Mitsubishi Lancer Register Forum (https://www.lancerregister.com//index.php)
-   Gearbox / Clutch / Transmission (https://www.lancerregister.com//forumdisplay.php?f=4)
-   -   Evo 7 GT-A transmission fluid flush/change advise? (https://www.lancerregister.com//showthread.php?t=582301)
dnlbrds 05-06-2019 02:21
Just double checking before I buy anything. I'm planning on using AMSOIL specifically the signature series ATF fluid (ATFPK-EA), and I would need approximately 7.8 Liters to fill? Also looking to replacing my transmission fluid filter and gasket and could not find anything online, but I am under the impression that I could buy a EVO 8 or 9 one and it should still be good? if not, would anyone be able to link me where to buy online, preferably one that can ship to Canada
Babylon6 11-06-2019 21:40
Hi. You cannot change the transmission filter without taking the box entirely apart. Normally you just need a replacement drain plug washer, your ATF (Amsoil is great) and a bit of time.
7.8 is enough to do a simple change, ie dropping the fluid.
When you refill the ATF wrap a towel around the filler neck and as you add the fluid , stick a cloth over your funnel because it gurgles and spits ATF everywhere!
Post up if you find any metal crap stuck to you drain plug (its magnetised).
