Mitsubishi Lancer Register Forum
Mitsubishi Lancer Register Forum (https://www.lancerregister.com//index.php)
-   MLR Platinum Option Trader: Auto Torque (https://www.lancerregister.com//forumdisplay.php?f=149)
-   -   ABS fault? - Evo 4-9 ABS rings now available (https://www.lancerregister.com//showthread.php?t=474362)
[email protected] Torque 05-02-2014 15:13
Do you have a ABS light on your dash? - A very common problem is that the trigger wheel/ABS ring on the end of the drive shafts crack causing a faulty reading.
We now can supply Evo 4-9 front and rear ABS rings for just 29.00 each delivered, a cheaper alternative to buying a complete drive shaft.
http://i1281.photobucket.com/albums/...ps2934bbaa.jpg
http://i1281.photobucket.com/albums/...ps15348eb6.jpg
Chris
mart1983 04-03-2014 17:46
hi chris, how much would you charge to supply and fit?
[email protected] Torque 04-03-2014 17:57
Hi Martin,
55 + vat each corner sir, supply and fit.
Chris
Wooffy 29-07-2016 20:31
Chris do you stock the front rings for an 04 VIII fq260? Every listing I find is for the wrong size rings, Mine are 43 tooth, 60mm inner 80mm outer and 7mm thick.
Steve.
Pedbuch 29-07-2016 20:48
would that cause an intermittent abs fault light?
river evo 6 29-07-2016 21:17
Hi ,my abs light comes on sparodically ,also feel a pulsing at slow braking speeds, on the brake pedal, could that be a symptom of this?
Cheers :smthumbup
Ramatzio 29-07-2016 23:55
Cheers :smthumbup
Yes! And gets worse as the gap in the ABS ring gets bigger
stu8 30-07-2016 09:14
Cheers :smthumbup
Flash out the stored fault code, that narrows it down to which corner, then start investigating, look at the ring, is it tight on the shaft (cant move it) any sign of cracks, teeth missing, or even chunks missing off teeth
Look at the sensor, follow it back to its connector, open that up and make sure the connection is good and clean. If the ring is good, its likely the sensor
Stu
kes205 25-07-2018 14:32
Do you still sell these abs rings?
Matthews512 30-06-2019 20:02
Hi are these still available ?
