Go Back   Mitsubishi Lancer Register Forum > Technical > Bodywork / Detailing
Old 13-08-2017, 09:37   #1
kes205
Car: EVO VI GSR
Clear coat for carbon fibre
Hi
I am going to try and refinish my carbon fibre coil pack cover and wondered if anyone can recommend a clear coat to use. The clear coat has yellowed and has cracks so was going to rub it down with wet and dry and then spray with clear coat. Was thinking I would use hycote vht clear but is there anything better I should use.
kes205 is offline   Reply With Quote
Old 13-08-2017, 14:31   #2
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
depending on how its made you wont get rid of the yellow and the cracks wil allways show ,its the cheap resins that there made of .
"Of all the branches of men in the forces there is none which shows more devotion and faces grimmer perils than the submariners."
Sir winston churchill
Old 13-08-2017, 14:53   #3
kes205
Car: EVO VI GSR
Oh well shall give it ago as have nothing to lose as doesn't look great at all. So hopefully it will end up looking better than it currently does.
Old 13-08-2017, 15:14   #4
gary evo7
gary evo7's Avatar
Car: evo x 330 sst
I just used normal clear coat on my bonnet vents came up reasonable but as said above the yellowing is still there just not as noticeable.
gary evo7 is offline   Reply With Quote
Old 13-08-2017, 15:15   #5
Leo6072
I've used spay max two pack clear coat with great results got it on amason for about £15 a can great stuf to activate you hit red cap on underside of can if you don't use it all stays useable in can for a few days drys quick flats off ok finish super hard great stuff made in Germany
Leo6072 is offline   Reply With Quote
The Following User Says Thank You to Leo6072 For This Useful Post:
river evo 6 (13-08-2017)
