Old 15-12-2010, 14:48   #1
jameswwt
Upgrade advise on stock 560cc Injectors...
Hi Guys,
im planning to upgrade my stock 560cc injectors to either 750cc or 800cc injectors.
1) But before i purchase the new larger injectors, how do i know is it plug and play direct replacement to my stock injectors?
2) Which is better (Low or High Impedence) and what is the different of the both???
3) What type (Top or Bottom fed) is our Evo injectors?
4) Lastly, will putting in a larger CC injectors can increase hp and reduce turbo lag?
Thanks and im looking at 350~380whp...
jameswwt is offline   Reply With Quote
Old 16-12-2010, 07:26   #2
jameswwt
Originally Posted by jameswwt View Post
Hi Guys,
Anyone mind to share???
Old 16-12-2010, 07:33   #3
Gary @ APT
Gary @ APT's Avatar
Car: Evo VII
Send a message via MSN to Gary @ APT
contact ross at rosssport he can sell you direct replacements
Gary @ APT is offline   Reply With Quote
Old 16-12-2010, 08:19   #4
RobCrezz
Geek
Car: Evo VI
I can only help with no 4)
On their own injectors wont reduce lag or increase power unless your current injectors are maxxed out. If you have a big turbo and cant increase the boost because your injectors are too small, then they will increase hp (with a remap).
1999 Evo 6 GSR 348/355
Previous Jap cars:
2002 EP3 Civic Type R - 1993 MR2 Turbo Rev3 - 1989 S13 200SX Turbo - 1994 Prelude 2.2 Vtec
RobCrezz is offline   Reply With Quote
Old 16-12-2010, 08:24   #5
AlexEvo
Car: Lancer Evo VI RS2
I'm not sure you need largers injectors to achieve your goals.
As said above, you'll need to upgrade them if the stock ones are maxed out when remapping.
EDIT : my mistake, I've read "hp" instead of "whp"
AlexEvo is offline   Reply With Quote
Old 16-12-2010, 08:43   #6
straightliner
Car: Evo 6 GSR
Stock injectors wont flow 380hp at the wheels
straightliner is offline   Reply With Quote
Old 16-12-2010, 09:32   #7
jameswwt
Thank you so much guys but will a 750cc injectors able to cater for 380whp?
Lastly, can anyone share what is the different between Low & High Impedence Injectors?
Old 21-12-2010, 16:38   #8
szeni
U need top feed mate
szeni is offline   Reply With Quote
Old 21-12-2010, 17:41   #9
evonut270
Car: evo 2 with an 8 ecu
750cc should see 380WHP
The impedance is the resistance of the injector solenoid windings. Evos have low impedance or "Peak and Hold" as there known.
evonut270 is offline   Reply With Quote
Old 21-12-2010, 17:51   #10
simon_16v
GT CLUB DADDYS HOME
simon_16v's Avatar
Car: Tme painted job,carbon, Roof bonnet sideskirts Rear spats boot Bumper diff mirrrors and carbon bride
Rc 1600 better to over spec fella
And your luck is in I have a set for sale lol
simon_16v is offline   Reply With Quote
Old 22-12-2010, 16:03   #11
jameswwt
Thanks Guys...
Old 31-07-2014, 19:55   #12
rgvrip
User
Just reading through the this ... Are all evo's low impedance??
rgvrip is offline   Reply With Quote
Old 01-08-2014, 03:38   #13
supafly_mx
Hi Guys,
- I recommend Sard injectors. I Purchased Sard 800cc ones for my EVo6 when I installed Evo9 turbo. Check there website as it has part numbers for Evo's think its part number : 63518 (Low imp)
Evo's are generally Low
-Top feed
Nope.Will help if you maxing injector cycle.
I make 245kw atw on my TME with Evo 9 80 series turbo,Apexi power fc,sard 800cc, hks272, 3" apexi nur spec from turbo cat back exh, and 1.5bar boost and apexi sus filter if that helps
supafly_mx is offline   Reply With Quote
Old 13-09-2017, 23:01   #14
gaz007
Car: evo 6 tme ,gems ecu ,mapped by steve simpson,,380bhp 359lb ft t apexi ebc,
Top feed and low imped is the type you need.Stock would be maxed out at about 360bhp ish and yes could manage but at limit i went over kill and had 800cc running at 70% duty on just under 400bhp at wheels.
shaken but not much
gaz007 is offline   Reply With Quote
Similar Threads
560cc injectors tonyj Private Sales - Parts 3 19-10-2010 22:33
Who runs a forged 2ltr with IX turbo, stock mivec cams & injectors????? Wirral_EVOIX Technical Questions 50 02-04-2010 10:17
Fitting 560cc Injectors to a EVO 4 J88HNB Technical Questions 9 09-02-2008 22:33
Max Horsepower on 560cc Injectors Mat@MG Autos Engine / Turbo 14 12-04-2006 11:33
best turbo upgrade for stock manifold piterm1 Technical Questions 1 28-04-2004 22:32
